Allow conda to create an environment without cloning.
1909
06-18-2021 04:37 PM
Status: Closed
Brian_Wilson
Honored Contributor
The only option for creating a new conda environment in ArcGIS Pro is "Clone Default". There is no way to create an environment for a specific task without copying all the packages from an existing environment.
3 Comments
TimJohnston3
I don't mind cloning the arcgis default environment, but I wish it went faster!
I wonder if ESRI can find a way to speed up cloning the default.
ShaunWalbridge
Could you provide some context to what you'd like to see in terms of making a new environment? The Python environment creation is geared around making Pro-compatible environments as most users later expect to use them with Pro. Are you interested in making environments that aren't connected to Pro and contain an arbitrary set of packages? If so, you may also be interested in Anaconda Navigator.
KoryKramer
Status changed to: Closed
Closed pending clarification.
