Allow ArcGIS Pro Catalog pane/view to cut/copy/paste whole folders
5077
11
02-19-2020 02:45 AM
Status: Implemented
TobiasTkaczick
For a proper data management it is essential that not only single files but also whole folders can be copied and/or moved via the ArcGIS Pro Catalog. A workaround via Windows Explorer contradicts the idea of integrated geodata management with ArcGIS.
11 Comments
ThomasColson
Wonder why this feature was removed. Copy n' paste folders works in Arc.
DEAF_PROBERT_68
Needs to add this Move to or Copy to within the ArcGIS Pro to avoid the break link .
NaicongLi
klf
Agreed, this should be do-able but Copy is greyed out when a folder is selected in Pro Catalog view.
JamalNUMAN
It would be great if the ArcGIS Pro is enhanced to include this functionality. It’s used to be in ArcMap
DanielGluck
You can use the Geoprocess "Copy" or "Rename" in ArcGIS Pro  - it does the work.
But I certainly agree that ESRI should return the option to Copy & Paste with right click inside the Catalog View.
Daniel
NaicongLi
JamalNUMAN
Good news that it’s in the production plan
CarlosGutierrez4
Yes, definitely good news that this is in the product plan but very disappointing that this functionality wasn't there to begin with.
KoryKramer
This functionality has been added in ArcGIS Pro 3.0. See Ideas in ArcGIS Pro 3.0  to see this and all of the other ideas you can look forward to when you upgrade.
Also be sure to check out the What's New documentation: https://pro.arcgis.com/en/pro-app/latest/get-started/whats-new-in-arcgis-pro.htm
