Advanced Arcmap Settings
1775
06-25-2010 04:57 AM
Status: Closed
JeganSomu
Add Advanced ArcMapSetings.exe to the Arcmap or Arc Catalog will be appreciated.
Bcoz to edit or make a custom changes to ArcMap, one has to go in search for the exe inside the directories.
Instead of doing that, if we create a seperate tool or a submenu inside the Tools Menu will reduce the work of customizing arcmap. The user can easily change the interface settings in Arcmap, on the go. That is from being in the arcmap itself.
I think this would be appreciated by more people.
3 Comments
ChrisSergent1
This should be added because it just makes sense. Same request for ArcMap here with 150 points.
https://community.esri.com/ideas/1803
SueCarroll
It would also go along way to getting around running ArcGIS in a Citrix environment, where we don't have access to the .exe files, etc.  Any direct access to these types of things would help - especially since a lot of places are moving to remote/client-server/"cloud" strategies and taking the direct access away from the end users PC. (I'm not even able to download and install tools and dlls without contacting IT and submitting a Work Order!)
ValeriaChavez
Status changed to: Closed
Hi @JeganSomu
ArcGIS Desktop is in mature support and will be retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application.
Thank you for taking the time to share your ideas. We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
