Adding classes in "Manual" classification method
7794
6
12-02-2013 06:03 PM
Status: Already Offered
LauraBates
When symbolising quantities, and classifying using the manual method, you can't change the number of classes. The classes box is greyed out, so you can't click on it, and so is the right click option to insert a break. If you need another class the only way i have found is to change the method (wiping all the breaks you have manually set), change the classes and then change it back to manual. Can we please have an option to add classes for this method?
6 Comments
wayfaringrob
Per this thread, it is not currently possible to modify the number of classes when using manual interval classification in graduated color symbology. The number of classes is there, but it is grayed out. There is a workaround, but it is tedious and destroys any values and symbology already set - flip to another method, add a class, flip back to manual, and reset your class breaks and symbology manually. That's not ideal, so I'm looking for the class number selector to be enabled here.
ZihanSong
Hello,
As one comment mentioned in the previous thread, this is by design. Because with customized classes, it will be hard for us to decide where to add a new one or to remove which class. Any action might ruin existing manual classifications, so we grey out the classes control.
W have this more flexible function to update classes: if you right click on a row, you can choose to add a break above or below, and this will update the number of classes and don't need to switch to another method. Hope it will help.
wayfaringrob
@ZihanSong  never would have thought to look there, thanks!
KoryKramer
Marking this as Already Offered per Zihan's response. As she showed, you can insert break above or insert break below. You can also switch to the histogram and manually insert breaks where you need:
B_Etter
@ZihanSong I have been working on a map for nearly an hour... so frustrated but your tip allowed me to finish in minutes.
Thank you!
wayfaringrob
@B_Etter  agree that this is a far from intuitive "solution." I forget this exists, and I see students not know how to fix it either.
