Please, add XMP metadata support for Reality Mapping image importer. Today (at Pro 3.1.2) it reads EXIF only which causing some digits fall down from the coordinates. For example the Z coordinate stored in EXIF is 250, imported as 250, but in XMP we have two extra digits: 250.54 m. In some high-precision workflows this is important not to loose two digits. The XMP also stores the relative height above the ground which could be used as a constant flight height in the detailed settings.
