Add Undo option when Calculating Geometry
698
01-03-2023 10:01 AM
Status: Under Consideration
MiguelMartinezYordan
Please add the Enable Undo down button when doing a Calculate Geometry operation. Only the Calculate Field has that option.
4 Comments
DrewFlater
mejohnson22
In our environment, we prefer to have users Enable/Disable editing from the Edit tab. We are using traditional versioning in ArcPro 3.1.4. We have found when using Calculate Geometry on the Attribute Table to calculate lengths the update occurs in the table and the "Save" button remains greyed out. If a user, does not physically disable the Edit Session or perform other edits that require the "Save" button, the changes do not stick. These changes could either automatically save so that if a user closes out of their project without disabling the "Edit" button the edits are still saved or require the "Save" button to commit the changes to match normal editing workflow.
DaveWilcox
We experience the same issue as mejohnson22. Calculate geometry does not mark the features as having been edited and edits are lost if we stop editing without making another edit. This appears to be a bug. We are at 3.2.2.
ChrisUnderwood
For tracking purposes: this is registered as defect ENH-000157071, Public Status = In Product Plan
"Calculate Geometry does not have an undo toggle and will not be listed in the save edits operation when running in an edit session"
