Add resizability to windows
892
02-26-2017 06:39 AM
Status: Closed
SharifulIslam
Hi all involved,
It would be a great if I have ArcMap with windows that is expandable as below image:Dataframe window
See the above picture of Dataframe window that is not expandable  in four ways.
In some case I need to expand this window e.g. I need to scroll to see the coordinate system of the three layers in the TOC, I need to see them substantially to compare them if there is any parameter/text different for one of those three layers. If I have window which I can expand upward and downward then comparing would be of great easy and I could grab the subtle change in the projection parameters while toggle selecting the three layers but now I need to copy projection parameters for each layers into notepad and compare them manually!! There so many software that implement this feature to ease the user interaction e.g. eCognition by Trimble as below:
resizability of eCognition
Tags (1)
2 Comments
DuncanHornby
Agree it is very frustrating that some dialogs do not allow you to expand the window, layer properties is another nightmare dialog and it's one which everyone is in and out of. I don't understand why this has never been resolved.
AubriOtis
Status changed to: Closed
Closing this as the issue is specific to ArcMap which is no longer being developed. Resizable windows are available in ArcGIS Pro.
