Add Refresh Map Series option to the layout context menu
2781
8
06-16-2022 07:29 AM
Status: Implemented
MarcelSt-Germain
Add, with the right clic menu, a refresh map series to be more intuitive than looking at the bar small icon.  Personally I put it just before Properties like "Refresh Map Series".
8 Comments
MarcelSt-Germain
Hi, maybe in v3 it will be done but, in a map series pages, if we had a map in the series define by a polygon layer it's not automatically added to the list.
So, at least add a refresh, in the right clic, if it's not possible to do that automatically.
For now, I have to change the field use for the map, then return to that field to see the new map available.
KoryKramer
@MarcelSt-Germain
Are you saying that the map series doesn't refresh if you add a polygon to the index layer?
If that is what you're asking, could you try Refresh Map Series?
If you are talking about something else, please provide more details and screenshots so that we can better understand the idea. Thanks!
MarcelSt-Germain
Hi Kory,
Sorry, your right, I forgot about the button, it's working.
But the idea of adding this refresh on the right clic menu still good and more intuitive.  Personally I put it just before Properties like "Refresh Map Series".
Now still waiting to see if a real map series for annotations will be available in v 3 
KoryKramer
Thanks, Marcel. Since the refresh functionality for map series already exists, in order to re-open this idea, it will need to be more specific. Can you modify this idea's title to "Add Refresh Map Series option to the layout context menu" ?
And update the ideas description to reflect that the request is to add the command to the context menu?
Once that is done we can re-open the idea.
Thank you!
MarcelSt-Germain
Hi Kory,
Sorry, I can't find the way to make modification.  Try "Options" Then "Modifier le message" but nothing append.  So, I will make a new one.
AubriOtis
AubriOtis
This was added in ArcGIS Pro 3.3.
MarcelSt-Germain
Funny but since 3,3 is bug, I will have to wait for an other version.  Maybe one day.
