Add Join — If previous join table is removed from map, leave Join Table parameter blank
1593
01-14-2024 03:01 AM
Status: Open
Bud
Esteemed Contributor
ArcGIS Pro 3.2.1; file geodatabase:
I have tables A and B added to the map. I create a join from A to B. Then I remove the join and remove table B from the map.
I add table C to the map and try to create a join from table A to C. The Add Join tool has remembered the table B join and has populated the Join Table parameter with information from table B. But that produces a pre-error since table B is no longer in the map.
Error 000732 Join Table: Dataset <my table> does not exist or is not supported
Rather than remember table B and produce a pre-error, it would be better to leave that parameter blank if table B no longer exists in the map.
Could that behavior be changed?
Video:
