Add GUID Field for coded Domains
1911
10-25-2018 07:43 AM
Status: Open
JeanBissonnette
Make GUID field able for make coded domain and make TableToDomain_management tool able to use GlobalID and OBJECTID for coded_field. If you have a little table with a list of thing and you want to make use a GlobalID or ObjectID for coded value.
Exemple :
>>> arcpy.TableToDomain_management('Prototype.gdb\\Adresse', "GlobalID", "Titulaire", 'Prototype.gdb' ,"_Exemple_GUID", "_EXEMPLE_GUID", "REPLACE")
Runtime error  Traceback (most recent call last):   File "<string>", line 1, in <module>   File "c:\arcgis\desktop10.5\arcpy\arcpy\management.py", line 1815, in TableToDomain     raise e ExecuteError: ERROR 000308: Invalid field type
3 Comments
KoryKramer
Jean Bissonnette‌ I'm not sure I understand the use case here.  ObjectID and GlobalID are system-generated values and both will be unique to each record in a table.  Why do you need to create a coded value domain using these field types?
JérémiePedoia
When you want to populate a GUID field in Survey123 from an other related table by this GUID, this could be usefull to build a domain on this GUID.
YoannRONCIN
It's sometimes easier to add to a relation using domain values when there is not a lot of features in the linked table.
