Add geoprocessing tool that exports geo pdf map using parallel processing
494
12-07-2015 07:25 PM
Status: Closed
GlenRouse
I have just been painfully watching my computer export a geo pdf using one CPU of my Quad core.  I still have plenty of memory, CPU is maxed out at 25%.  It has been almost 50 minutes.
It would be swell to have a geo processing option that would use more CPU power.
3 Comments
RobertBorchert
Can you expand on your techniqe you are using and your settings?
How large is your MXD?
What type of database are you working off of?
How large of an area are you tyring to export?
I just exported a Georeferenced PDF of a township and it took about 5 seconds.
GlenRouse
The MXD is a little over 1.7 MB, All the data come from two separate file geodatabase which are about 85 MB and 1.31 GB respectively. The area is large 30 miles by 30 miles at 1:12,000 scale.
The map contains roads, streams, harvest units, contours etc.
AubriKinghorn
Status changed to: Closed
This idea is for ArcMap, which is being retired. ArcGIS Pro has a more modern software architecture to take advantage of computing power.
