Add ArcScene window in layout.
909
05-09-2012 03:17 AM
Status: Already Offered
PalomaSánchez_Méndez
To be able to add a dataframe inside the map composition including 3D (ArcScene) data. They now use a screenshot and adding it to the map.
Tags (1)
2 Comments
I need to create maps with views and data differents, this data are DEM and map data in 2D. I would like to merge several data in the layout view and in the Data view and I think the best way is integrate the AcrScene into ArcMap like is has made with ArcCatalog.
Then I will can view the data in three dimension and to use the analisys in one step.
Paloma S.
AubriOtis
This is available in ArcGIS Pro
