Add ArcMap-esque a 'canceled' indicator when the drawing of a map is canceled
2559
12
04-18-2022 01:40 PM
Status: Closed
wayfaringrob
Honored Contributor
ArcGIS Pro is much better at not cancelling the drawing of your map than ArcMap. However, it still happens:
What's worse is that there's no indicator that this is happening as there is in ArcMap:
I'd like to see some sort of indicator, whether it's that same 'Canceled' label appearing somewhere or adding a new icon to that status bar that shows as a green checkmark/red cross type of thing. I could see the argument for a temporary green check appearing when it's done drawing, and a persistent red x if there are errors.
Tags (1)
12 Comments
wayfaringrob
@KoryKramer  thanks! I don't use GIS as frequently these days but it looks like what you've added will get the job done.
KoryKramer
Status changed to: Closed
Thanks @wayfaringrob We'll close this for now as we did do a lot of work to add drawing alerts in Pro as noted above. Any other new ideas against the current software can be submitted separately if needed. Thanks again.
