Add a Default option when exporting layouts
855
05-29-2024 06:57 AM
Status: Open
MiguelMartinezYordan
When you are exporting a map or a layout, there are multiple options that remain saved after closing the project. If you add a Default button at the bottom, you can go back to the original settings if you are not sure what you change the last time.
Tags (1)
3 Comments
AubriKinghorn
Hi! This sounds similar to export presets, which are already available in ArcGIS Pro. Have you been able to use them in your workflows?
RTPL_AU
@AubriKinghorn Presets are useful but having a "Default" button in the Export Map/Layout window will be handy to have to quickly get back to OOB state after messing around for a specific purpose or chasing a bug feature.
You have all these file types:
 but only these default presets (in the ribbon, in a completely different location from where you likely are when using an Export shortcut in the QAT or  Cool Tools).
AubriKinghorn
Status changed to: Open
