Add a button to switch back and forth between Catalog View and Catalog Pane for the same item.
1689
11-12-2021 09:25 AM
Status: Under Consideration
RandyCasey
What if the button just swapped back and forth between the two views? Sometimes I need to work in the Catalog View to find an object, but then I might need to add it to a map or copy it to another location, which works great if you have the Pane and View open at the same time (drag from one, drop on another). Here's a sample of how I would see a more efficient workflow:
I search for an object in the View, find it, right-click and open it in the Pane, then navigate the View to my destination folder or switch to a map, finally drag the object from the Pane and drop it in the View or Map.
This would also work for dropping objects into the Python window too, as it is easier to grab an object from the Pane and drop it into a Python window (because the Pane has a smaller footprint, and typically my Python window is pretty big).
1 Comment
NaicongLi
