Ability to Clear Recent Maps from the Getting Started Window
2762
02-12-2014 06:37 PM
Status: Closed
BenVan_Kesteren1
Hi All,
I would like to suggest the implementation of a button within the ArcMap options where the user is able to clear the recent maps list of its items. I have found using the 'help' that we can clear this list with the Registry Editor, but as a user within a company I do not have this permission, and I assume many other users would also struggle with permissions.
Can ESRI create a simple button that we can reset the 'recent maps' area to be empty....
The reason I ask, is because I recently created some new templates for myself, and saved them into the template directory so they will act as templates (obviously), but now every time I load ArcMap they appear in my Recent files list, which is not a good idea as I can accidentally (if not paying attention) load the template and edit that, instead of loading it as a template, which forces me to save as a new map... Have I confused everyone??? 😕
0EME0000000Tjzv
Cheers
4 Comments
DarrenPlatakis
I meant to promote this. I accidentally demoted it...  ARGH!! It won't let me change the vote!
JoshuaDamron
Great idea, I have low level GIS users who only need to see the one .mxd that they use and not get confused by previous versions or other .mxd's that may have been opened on their computer at some point in the past.  it would b egreat to beable to dump the files that are no longer relevant.
AndrewPfeifer
Having the ability to right click on an item and remove it individually from this screen would be perfect.
NaicongLi
Status changed to: Closed
In the Start Page of ArcGIS Pro, you can selectively remove a project from the Recent Projects list to clean up the list:
We are closing this idea since ArcMap and ArcCatalog are in mature support.  We will however continue to improve the functionalities of the Recent Projects list, for example a solution to easily clear the entire Recent Projects list in ArcGIS Pro.
