ArcGIS Pro Roadmap - November 2025
3650
a month ago
ArcGIS Pro 3.6 was released on November 13, 2025. For information on the latest updates, refer to the ArcGIS Pro 3.6 Release Notes.
Our goal is to build the best GIS software available. This ArcGIS Pro Roadmap* gives you a sneak peek of what we're focusing on for the near-, mid- and long-term of ArcGIS Pro development. It gives our current estimate of when each capability will be released. New capabilities will be made available for beta testing through the Early Adopter Community prior to a release and we'll revise the roadmap throughout the year to ensure it reflects the latest information.
What would you like to see next in ArcGIS Pro? Share your ideas in the ArcGIS Pro Idea Exchange.
If you're interested in contributing to the development of ArcGIS Pro, gaining early access to beta versions, and engaging with the team to provide meaningful insights for improvement, sign up to participate in the ArcGIS Pro Early Adopter Community
Additionally, we have an exclusive opportunity to participate in the development of ArcGIS Pro's AI-powered assistant. We are currently accepting applications for up to 1,000 users to join the ArcGIS Pro assistant (beta) Early Adopter Community. Apply here to participate.
* Capabilities on this roadmap are tentative and subject to change, delay, or cancellation. The continued development or release of a capability is at the sole discretion of Esri.
Near-Term (next release or two)
Customize Layer Visibility per Map Frame - Support overriding the map's visible layers in a layout map frame. This allows multiple layouts to show different data layers while pointing to a single map.
Layer & Feature Effects - Apply visual effects such as blur and drop shadow to layers or a subset of features for emphasis.
Customizable & Movable Toolbars Create custom toolbars of commands that you use most and move them around to keep them close to your work to boost productivity.
OneDrive Integration - Enable OneDrive integration and connect to a Microsoft work or school account linked to Microsoft OneDrive on your computer to prevent simultaneous editing of certain files in ArcGIS Pro. This integration is not a solution for collaborative workflows on the same ArcGIS Pro project - use portal projects to collaborate with others on the same project at the same time. OneDrive integration is designed to maintain the integrity of project files (.aprx) and other key file types such as file geodatabase, style files, toolboxes and server connection files. It will require users working on the same files to have the OneDrive experience enabled and will be controllable by administrators through application settings.
Enterprise Geodatabase Feature Cache – Enable feature caching from enterprise geodatabases. The feature cache allows you to temporarily store features in the current map display in your machine’s local memory which can speed up common tasks.
Timeline View - Visualize your data along a temporal axis. Timelines complement the spatial view of your data on the map by showing where in time your data falls. By plotting your data along a timeline, you can understand the temporal order of your data and discern temporal trends that emerge.
File Knowledge Graphs - This new capability brings the power of connected data, link analysis and graph analytics to locally stored files. Users will be able to create or read independent file knowledge graphs, integrate structured data from a variety of sources, and then explore that connected data in a variety of independent views within their Investigation, using Link Charts, Maps, pathfinding tools and graph queries (openCypher). Local file knowledge graphs will be able to be published to ArcGIS Enterprise to scale workflows across organizations through desktop, web applications and developer APIs.
Plume Simulation - Use air-quality dispersion simulation to predict pollutant concentrations for current or future scenarios in varying weather conditions, and use the results for health analytics and comparison to air quality standards.
3D Export - Select a limited Area of Interest (AOI) in a scene and export the contents to common 3D exchange formats such as STL or glTF for use in other applications.
ArcGIS Pro Assistant (public beta) – ArcGIS Pro users get support from an AI-powered assistant to increase productivity in several areas. The assistant will be able to answer questions using ArcGIS Pro help documentation, generate SQL and graph queries, create Arcade expressions, produce ArcPy code snippets, perform actions within the application, guide users through the planning and execution of complex GIS workflows, and automate common tasks by building and configuring custom agents.
Edit Templates in the Database – Ability to store edit templates authored in ArcGIS Pro in a database and use within ArcGIS Pro, or outside of ArcGIS Pro through a feature service.
Extract Vector Features from Scanned Images/PDFs – Convert scanned images into vector-based feature layers using a geoprocessing tool.
Telecom Domain for Circuit Management - The Telecom domain is designed to provide grouping for fiber/ports, tracing specific to communication networks and telecom-based circuit management (as opposed to electric circuit configurations).
National Spatial Reference System Modernization for North America - US National Geodetic Survey (NGS), Mexico's INEGI, and Canada's CGS plan to release new coordinate systems and transformations in 2026 including four new geodetic coordinate systems and a new vertical coordinate system plus geoid model. In the US, there will be around 1900 new projected coordinate systems ranging from low distortion projections to statewide zones.
ArcGIS Pro 3.7 Moves to .NET 10 - .NET 10 is the latest long-term support (LTS) version of .NET. ArcGIS Pro 3.7, planned to be available in Q2 2026, will require .NET 10.
Mid-term (next two or three releases)
Dispersed Points Visualization - Dynamically disperse overlapping point features when drawing feature layers.
Support for Attribute Editing Forms - The first phase of this project will provide support in ArcGIS Pro to use attribute editing forms created in other ArcGIS applications (Map Viewer and Field Maps Designer). The second phase will provide support for building and configuring forms from ArcGIS Pro.
Point Cloud Scene Layer Data Management - Add, Delete, Change very large point cloud services based on reference data sources.
Materials Authoring - Author properties to support reflectivity, roughness and other properties for more photo-realistic visualizations in 3D scenes.
Mesh Segmentation Models - Mesh Segmentation will provide the ability to train and use deep learning models for identifying parts of a 3D mesh as objects such as trees, buildings or roofs.
Oriented Imagery: Live Video Superposition and AI Integration  - Superposition of live video streams onto surfaces of objects (flashlight mode) enabling live representation of scenes from multiple image sources. Tight integration with ArcGIS Image Analyst Extension based AI workflows for creating training data, training models and inferencing. Integration with pre-trained models such as face blurring, car number plate blurring as well as a range of feature extraction such as road signs. Users will be able to drive to a collection of images, features or labels to collect or review attributes.
Reading Alignments from IFC - Building Smart International is actively working on expanding the IFC standard to include more infrastructure support, including things like rail, tunnels, and roadways.  To address the anticipated needs, this project builds on our current capabilities to read 3D elements from IFC to include alignments and other linear elements as part of our BIM model support.
Direct Read OpenRoads Designer Files - This initiative allows access to engineering information currently locked within Bentley's ecosystem. OpenRoads Designer is a CAD/BIM file format used by Civil engineers for infrastructure design.  It is used by almost all DOT's and AEC firms that support the transportation industry.  We'll provide the same level of functionality as we do with Civil 3d, interpreting 2d and 3d engineering information as GIS features.
Business Systems Integration - Allow organizations to create live connections to external systems such as ServiceNow, Salesforce, and so on to enrich spatial data stored in ArcGIS with their live business data without duplicating data.
Feature Service to Feature Service Sync Allow syncing of row level edits between two feature services. You will be able to sync between services in ArcGIS Enterprise with ArcGIS Online, ArcGIS Enterprise with ArcGIS Enterprise, or ArcGIS Online with ArcGIS Online depending on workflow requirements.
Long-term (in the plan but not assigned to a release at this point)
Share ArcGIS Pro Model- Author a ModelBuilder model in ArcGIS Pro and share it as an item to ArcGIS Online or ArcGIS Enterprise. You will be able to view and run the model from a browser. You will also be able to download, view and run the model in ArcGIS Pro projects.
Street Name Index for Layouts -  A new layout element to show where street names, or other features are located within a map grid or across map series pages. Various options for formatting the text will be available.
Terrain Editing -  Ability to interactively edit the ground or other surfaces.  Add, remove and replace data referenced by the surface.
High Fidelity Rendering - A series of display improvements to support more photo-realistic 3D scene visualizations.
3D Mesh as Ground - The ability to use integrated mesh or TIN information as a true triangulated ground surface that would be more precise than raster surfaces and allow structures such as tunnels and mines.
Integrated Mesh Scene Layer Data Management - Add, Delete, Change very large integrated mesh services based on SLPK.
Cloud Drive Support - Support storage of ArcGIS Pro files and data in common cloud drives in addition to OneDrive.
Infrastructure-less IPS - ArcGIS IPS will not rely on the installation of dedicated hardware.
Comments
Gisbert61
Why are my model parts unreadable small after upgrade to 3.6? Surely there must be some setting to normalise this?
Version history
Last update:
a month ago
Updated by:
Contributors
