ArcGIS Pro Labels
9575
11-11-2020 07:28 PM
ArcGIS Pro Labels
ArcGIS Pro idea submissions require a single label; that is, an idea cannot be submitted without a label or with more than one label.  Use this table to help find the label that best aligns with the idea you're submitting.  Do your best to label your idea correctly and as Ideas Managers review ideas, they will update the label if necessary.
Use Ctrl + F to search for keywords in the description
LABEL
DESCRIPTION
3D Data & Editing
3D editing, 3D object feature layer, COLLADA, DAE, DWG, FBX, glTF, glb, IFC, OBJ, USD, materials, multipatches, 3D geometry, 3d formats
Annotation & Labeling
labels, annotation, Maplex, dimension feature classes, text symbols
Application Framework
install, update, pane and ribbon behavior, customization, assigning shortcuts, add-in manager, diagnostic monitor
Arcade
Use this label for ideas requesting features or functionality related to the Arcade language. Note that there are areas of ArcGIS Pro where Arcade is used, but where the idea may not be about the language itself such as Annotation & Labeling, Geodatabase, and Geoprocessing.
arcpy
arcpy site package
arcpy.mp
ideas specific to working with arcpy.mp
CAD-BIM-Revit
CAD, BIM, Revit, Civil 3D
Charts
ideas specific to working with charts
Content Management
browse and search, Catalog Pane, Catalog View, favorites, metadata, notifications, offline maps, project packages, project save, project templates, start page
Documentation & Help
web help and offline help, including quick-start tutorials, what's new, release notes
Editing
feature and attribute editing, attributes pane, feature templates, editing grid, constraints, snapping, topological editing
Export Print & Display
Export, printing, display, and ArcGIS Pro hardware requirements
GeoAI
GeoAI, deep learning, natural language processing, text analysis, object detection, feature extraction, model training, AutoML, artificial neural networks, pretrained models
Geocoding
addresses, locators, rematch pane, locate pane, layer search, world geocoding service, reverse geocode, what’s here
Geodatabase
archiving, attachments, query layers/oledb(odbc), data design (fields view, domains view, subtypes view, contingent attribute values, attribute rules), file-based data (csv, txt, Microsoft Excel), editor tracking, geodatabase administration, replication, linear referencing, joins, relates, relationship classes, database view, topology, versioning
Geoprocessing
geoprocessing (gp) tools, toolboxes, analysis, gp environments, gp favorites, gp history, gp options, scheduling tools
Imagery & Raster
raster symbology, raster functions, orthomapping, mensuration, image services, image classification, georeferencing, mosaic datasets
Knowledge Graphs
ideas related to knowledge graph functionality and link charts in ArcGIS Pro
Layout
layout elements (legend, scale bar, north arrow, dynamic text, layout graphics, pictures), layout files (.pagx), bookmark map series, spatial map series, map frame, table frame, chart frame, layout templates
Licensing
named user, single use, concurrent use, license manager, offline licensing, assigning licenses, borrowing licenses, authorization, activation, provisioning file, option file, ArcGIS License Server Administrator, silent authorization, json file
Map Authoring
symbology, layer properties, layer files (.lyrx), blend modes, map properties, coordinate systems, projections, transformations, map scale, map graphics, basemaps, Map Contents pane, color schemes /ramps, color management, spot color, colour, definition queries, query builder, display filters, stream layers, feature binning, map notes, renderers, representations, scale based, scale-based sizing, attribute driven symbology, heat map, graduated colors / symbols, bivariate, GNSS, GPS, stroke, fill, marker, glTF, symbol layer drawing, masking, repair data sources, visual variables, transparency, procedural, rule package, styles, catalog layers, clustering, dot density, clip layers, layer extent, subtype group layer, feature draw order, drawing alerts
Map Exploration
animated symbology, attribute tables, pop-ups (identify), navigation, animation, measure tools, reports, time, exploratory analysis tools, selections, bookmarks, map tips, coordinates, map units, visual effects, flood simulation, presentations
ModelBuilder
ModelBuilder ideas can be submitted directly to the ModelBuilder idea exchange. ArcGIS Pro ideas for ModelBuilder will be moved to the ModelBuilder idea exchange.
Multiscale Mapping
generalization, vector tiles, symbol effects, dictionary renderer, Electronic Navigational Chart (ENC) viewing
Parcel Fabric
Parcel Fabric ideas can be submitted directly to the ArcGIS Parcel Fabric idea exchange.  ArcGIS Pro ideas for Parcel Fabric will be moved to the Parcel Fabric idea exchange. In addition, ideas related to traverse, COGO, and ground to grid can be submitted using the Parcel Fabric label, or directly in the Parcel Fabric idea exchange.
Python
Python distribution, package manager, python environments, Notebooks
Scene Layers
building layers, elevation layers, integrated mesh layers, 3D object layers, point cloud layers, voxel layers, slpk, scene layer packages
SDK
SDK ideas can be submitted directly to the ArcGIS Pro SDK idea exchange.  ArcGIS Pro SDK ideas will be moved to the ArcGIS Pro SDK idea exchange.
Sharing & Publishing
sharing web layers, web maps, web scenes, packages, sign-in, portal connections
Spatial Statistics and Machine Learning
clustering, prediction, multivariate analysis, spatiotemporal pattern mining, forecasting, statistics, data engineering, data science, machine learning
Tasks
ideas specific to working with Tasks
Trace Network
ideas specific to working with Trace Networks
Usability (UI-UX)
ideas related to usability, user interface, user experience
Using Feature Services in Pro
ideas specific to displaying, querying, editing, or performing analysis using feature services in Pro
Utility Network
ideas specific to working with Utility Networks
Extension: 3D Analyst
ideas specific to working with the 3D Analyst extension; las, lidar, point cloud, tin, terrain, surface, multipatch, 3d, z, elevation, height, solid, dem, dsm, raster, interpolate, triangulate, triangulation
Extension: Business Analyst
ideas specific to working with the Business Analyst extension
Extension: Data Interoperability
ideas specific to working with the Data Interoperability extension
Extension: Geostatistical Analyst
ideas specific to working with the Geostatistical Analyst extension
Extension: Image Analyst
ideas specific to working with the Image Analyst extension
Extension: LocateXT
ideas specific to working with the LocateXT extension
Extension: Network Analyst
ideas specific to working with the Network Analyst extension, network datasets, and network analysis solvers (Route, Closest Facility, Service Area, Location Allocation, Origin Destination Cost Matrix, Vehicle Routing Problem, Last Mile Delivery)
Extension: Spatial Analyst
ideas specific to working with the Spatial Analyst extension
Comments
LisaDeAlessio
New Explorer
Content Management - The "Databases" section of Catalog should not allow you to delete the database, since you are mapping to another location. You should only be allowed to "remove" the mapped geodatabase, not delete it from here.
KoryKramer
Esri Esteemed Contributor
Hi @LisaDeAlessio The purpose of this document is to provide the Label name and corresponding descriptions to help community members understand how to label their ideas in the ArcGIS Pro idea exchange.
If you'd like to submit an idea there, please follow the submission guidelines.
Thank you!
Version history
Last update:
‎12-17-2025 01:54 PM
Updated by:
