It's that time again to do a little roll up of which Desktop ideas have seen status changes since the last update, https://community.esri.com/community/gis/applications/arcgis-pro/blog/2017/06/27/arcgis-desktop-idea....
4 Desktop ideas have been moved to Under Consideration:
Batch processing in ArcGIS Pro
Select by Location in ArcGIS Pro
14 Desktop ideas have been moved to In Product Plan:
Disable "Authorize ArcGIS Pro to work offline"
New Geodatabase Tool in Folders in ArcGIS Pro
Give us back the basic ability to create folders within dialog!
Remove warning when changing Subtype in ArcGIS Pro
Set symbol color from RGB values in attribute table
Undo field calculations in ArcPro
Map Service Enhancements on ArcGIS Pro
Python Scripting for Exporting Map Series in ArcGIS Pro
Add full COGO functionality to ArcGIS Pro
Split Polygon and Construct Polygons tools for ArcGIS Pro
As always, I hope that sharing these updates is insightful. I wanted to thank you for participating in the process and let you know that we’re listening!
