Pipeline Referencing Foundation implementation
3054
6
07-19-2023 07:53 AM
Cristian_Galindo
I made the deployment of the solution Linear Referencing Foundation version 1.2
Now following the task in the project , I calculated the Tolerances and Resolutions for CGS WGS 1984 spatial reference, now I am trying to make a Prototype in a single user environment:
arcpy.ImportToolbox(r"U:\UPDM\PipelineReferencingFoundationV1_2\Pipeline Referencing Foundation.tbx")
with arcpy.EnvManager(XYResolution="0.000000001 DecimalDegrees", MTolerance=0.0009988805323293938, XYTolerance="8.98315284119521E-09 DecimalDegrees", ZResolution="0.0001 Meters", MResolution=0.00011119487222222222, ZTolerance="0.0001 Meters"):
arcpy.udms.ChangeGDBSpatialReference(
gdb=r"U:\UPDM\PipelineReferencingFoundationV1_2\Databases\UPDM_PipelineReferencing.gdb",
spatial_reference='GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000 10000;8.98315284119521E-09;0.001;0.001;IsHighPrecision',
output_folder=r"U:\UPDM\PipelineReferencingFoundationV1_2\Prototypes",
output_name="updm.2021.wgs84"
but I receive an error:
Change GDB Spatial Reference
Parameters
Geodatabase     U:\UPDM\PipelineReferencingFoundationV1_2\Databases\UPDM_PipelineReferencing.gdb
Output Spatial Reference     GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000 10000;8.98315284119521E-09;0.001;0.001;IsHighPrecision
Folder Location     U:\UPDM\PipelineReferencingFoundationV1_2\Prototypes
Output Name     updm.2021.wgs84
Output Package
Environments
XY Resolution     0.000000001 DecimalDegrees
M Tolerance     0.0009988805323293938
XY Tolerance     8.98315284119521E-09 DecimalDegrees
Z Resolution     0.0001 Meters
M Resolution     0.00011119487222222222
Z Tolerance     0.0001 Meters
Messages
Start Time: Wednesday, July 19, 2023 3:32:05 PM
udms 3.1.1
Removed whitespace from the following geodatabase items:
	DataElement/LRSMetadata: '<?xml version="1.0"?>\n<Lrs xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" LrsId="B60E5FE6-20EC-44D6-B708-031CC63A7222" Name="APR" Description="" SchemaVersion="10" CenterlineFCName="P_Centerline" CenterlineSequenceTableName="P_Centerline_Sequence" CalibrationPointFCName="P_CalibrationPoint" RedlineFCName="P_Redline" ConflictPreventionEnabled="false" DefaultVersionName="" AllowLockTransfer="false" UseElevationDataset="false" ZFactor="0" UserSchemaPrefix=""><Networks><Network NetworkId="1" Name="P_EngineeringNetwork" FieldSeparator="" IgnoreEmptyRoutes="false" PersistedFeatureClassName="P_EngineeringNetwork" PersistedFeatureClassRouteIdFieldName="RouteId" FromDateFieldName="FromDate" ToDateFieldName="ToDate" PromptPriorityWhenEditing="true" GapCalibration="SteppingIncrement" GapCalibrationOffset="0" MeasuresDisplayPrecision="3" UpdateRouteLengthInCartoRealignment="false" IsDerived="false" DerivedFromNetwork="-1" RouteNameFieldName="RouteName" LineIdFieldName="LineId" LineNameFieldName="LineName" LineOrderFieldName="LineOrder" AutoGenerateRouteId="true" AutoGenerateRouteName="false" ServiceLayerId="-1"><RouteFieldNames><NetworkFieldName Name="RouteId" FixedLength="0" IsFixedLength="true" IsPaddingEnabled="false" PaddingCharacter="32" PaddingPlace="None" IsPadNullValues="false" IsNullAllowed="false" AllowAnyLookupValue="true" LookupTableXml="" LookupTableName="" LookupKeyField="" LookupDisplayField=""/></RouteFieldNames><EventTables><EventTable EventId="D624B1A5-A283-49E9-9F8F-B78354D37E6B" Name="P_Anomaly" TableName="P_Anomaly" FeatureClassName="P_Anomaly" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="B9480746-CC59-410C-BD5A-78DB6E7FDBB8" Name="P_AnomalyGroup" TableName="P_AnomalyGroup" FeatureClassName="P_AnomalyGroup" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="2A613774-1BA1-415F-AC43-6DCF09CAF14F" Name="P_Coupon" TableName="P_Coupon" FeatureClassName="P_Coupon" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="75340666-DF90-44A7-A878-D625725D409E" Name="P_DASurveyReadings" TableName="P_DASurveyReadings" FeatureClassName="P_DASurveyReadings" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="DEAF0F9E-B69B-426B-B9A8-F0C1C7D89737" Name="P_DocumentPoint" TableName="P_DocumentPoint" FeatureClassName="P_DocumentPoint" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="41B47270-29C0-44AD-BC80-402E44B29AF9" Name="P_Elevation" TableName="P_Elevation" FeatureClassName="P_Elevation" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="B45CF1DE-37C7-40C0-BBAF-E4D289CCBE0F" Name="P_IdentifiedIssue" TableName="P_IdentifiedIssue" FeatureClassName="P_IdentifiedIssue" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="2AC494AC-7767-4419-844E-EB09782E9B9C" Name="P_ILIGroundRefMarkers" TableName="P_ILIGroundRefMarkers" FeatureClassName="P_ILIGroundRefMarkers" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="2A64534D-14CE-4C2A-85F5-EF5AB6EB3BD6" Name="P_ILISurveyGroup" TableName="P_ILISurveyGroup" FeatureClassName="P_ILISurveyGroup" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="F5ECE749-CDBC-47B6-A297-905DC70E6F43" Name="P_ILISurveyReadings" TableName="P_ILISurveyReadings" FeatureClassName="P_ILISurveyReadings" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="DE0B5BC1-C9DF-4AAC-A375-72E9988D6727" Name="P_InspectionNote" TableName="P_InspectionNote" FeatureClassName="P_InspectionNote" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="0159DFA4-707F-476C-8960-E60CA32A18CD" Name="P_PipeCrossing" TableName="P_PipeCrossing" FeatureClassName="P_PipeCrossing" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="71FBDD31-6FD2-4684-BCA3-CEA019302275" Name="P_PipeJobSeparator" TableName="P_PipeJobSeparator" FeatureClassName="P_PipeJobSeparator" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="4A74643C-F384-4EA2-8A75-7ECC28B27F4B" Name="P_PipelineMarker" TableName="P_PipelineMarker" FeatureClassName="P_PipelineMarker" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="BD0DE7AC-8DBE-4C2A-B217-16F18AAEBEE2" Name="P_SqueezeOff" TableName="P_SqueezeOff" FeatureClassName="P_SqueezeOff" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="78A90935-1678-4C60-B3C4-545E77C9FD3D" Name="PipelineDevice" TableName="PipelineDevice" FeatureClassName="PipelineDevice" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="OBJECTID" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="4B2D53FB-3643-4A85-AD3F-473DEE48AAA7" Name="PipelineJunction" TableName="PipelineJunction" FeatureClassName="PipelineJunction" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="OBJECTID" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="BC9B1030-65AF-4922-9B0E-E68F247AC66F" Name="StructureJunction" TableName="StructureJunction" FeatureClassName="StructureJunction" IsLocal="true" IsPointEvent="true" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="OBJECTID" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="" ToRouteNameFieldName="" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engm" ToMeasureFieldName="" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continm" DerivedToMeasureFieldName="" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="2D804F58-BE2F-44E8-A074-12B8ACCCEB5D" Name="P_ConsequenceSegment" TableName="P_ConsequenceSegment" FeatureClassName="P_ConsequenceSegment" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="791CC765-B9C0-4BF3-823D-445093CC6A4E" Name="P_CouldAffectSegment" TableName="P_CouldAffectSegment" FeatureClassName="P_CouldAffectSegment" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="F13DDB92-BAB7-4782-9551-B25C7E42D7E4" Name="P_DOTClass" TableName="P_DOTClass" FeatureClassName="P_DOTClass" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="B8964AA0-4A77-4B02-9EA6-A7500CF8BDBF" Name="P_ExcavationDamage" TableName="P_ExcavationDamage" FeatureClassName="P_ExcavationDamage" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="4F432698-1967-4665-B538-D4CB9493B308" Name="P_ExposedPipeInspect" TableName="P_ExposedPipeInspect" FeatureClassName="P_ExposedPipeInspect" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="FBE7F9BA-A780-4E8E-8DE7-70083FCD1BB1" Name="P_ILIInspectionRange" TableName="P_ILIInspectionRange" FeatureClassName="P_ILIInspectionRange" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="AF2FDEF0-9414-4339-8D2D-28F6B7FF5165" Name="P_InlineInspection" TableName="P_InlineInspection" FeatureClassName="P_InlineInspection" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="A513F4BF-3717-4650-B92E-F09ABA988D17" Name="P_InspectionRange" TableName="P_InspectionRange" FeatureClassName="P_InspectionRange" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="C4247FA5-6314-4206-AF04-C76864BC5629" Name="P_LeakRepairs" TableName="P_LeakRepairs" FeatureClassName="P_LeakRepairs" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="69CD0D9F-3E23-48AD-A2E2-775265B74ED1" Name="P_MAOPCalcRange" TableName="P_MAOPCalcRange" FeatureClassName="P_MAOPCalcRange" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="82F14F4D-0028-4B62-A8CA-D17A475C86E0" Name="P_OperatingPressureRange" TableName="P_OperatingPressureRange" FeatureClassName="P_OperatingPressureRange" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="0B5E71B5-4E38-4B37-92B4-5FE71E2AFCC6" Name="P_PipeExposure" TableName="P_PipeExposure" FeatureClassName="P_PipeExposure" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="723862E0-7DBB-4299-ABE9-A9B05B377014" Name="P_TestPressureRange" TableName="P_TestPressureRange" FeatureClassName="P_TestPressureRange" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="DCA45B03-A469-4774-AC0C-5D7D58E71A56" Name="PipelineLine" TableName="PipelineLine" FeatureClassName="PipelineLine" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="OBJECTID" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="697AD7AB-AE56-4C3C-8EEC-3F331D0A9307" Name="StructureLine" TableName="StructureLine" FeatureClassName="StructureLine" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="OBJECTID" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/><EventTable EventId="A833D8FE-E81E-417B-8C24-19486EFE2479" Name="P_CenterlineAccuracy" TableName="P_CenterlineAccuracy" FeatureClassName="P_CenterlineAccuracy" IsLocal="true" IsPointEvent="false" ReferenceOffsetType="NoOffset" TableNameXml="" ObjectIdFieldName="objectid" EventIdFieldName="eventid" RouteIdFieldName="engrouteid" RouteNameFieldName="engroutename" ToRouteIdFieldName="engtorouteid" ToRouteNameFieldName="engtoroutename" FromDateFieldName="fromdate" ToDateFieldName="todate" FromMeasureFieldName="engfromm" ToMeasureFieldName="engtom" LocErrorFieldName="locationerror" StoreFieldsFromDerivedNetworkWithEventRecords="true" DerivedRouteIdFieldName="continrouteid" DerivedRouteNameFieldName="continroutename" DerivedFromMeasureFieldName="continfromm" DerivedToMeasureFieldName="contintom" StoreReferentLocationWithEventRecords="false" ReferentOffsetUnits="esriUnknownUnits" FromReferentMethodFieldName="" FromReferentLocationFieldName="" FromReferentOffsetFieldName="" ToReferentMethodFieldName="" ToReferentLocationFieldName="" ToReferentOffsetFieldName="" AheadStationField="" BackStationField="" StationUnitOfMeasure="esriUnknownUnits" StationMeasureIncreaseField="" StationMeasureDecreaseValues="" ServiceLayerId="-1"/></EventTables><IntersectionClasses/><UnitsOfMeasure>3</UnitsOfMeasure><RoutePriorityRules/></Network><Network NetworkId="2" Name="P_ContinuousNetwork" FieldSeparator="" IgnoreEmptyRoutes="false" PersistedFeatureClassName="P_ContinuousNetwork" PersistedFeatureClassRouteIdFieldName="RouteId" FromDateFieldName="FromDate" ToDateFieldName="ToDate" PromptPriorityWhenEditing="true" GapCalibration="SteppingIncrement" GapCalibrationOffset="0" MeasuresDisplayPrecision="3" UpdateRouteLengthInCartoRealignment="false" IsDerived="true" DerivedFromNetwork="1" RouteNameFieldName="RouteName" LineIdFieldName="" LineNameFieldName="" LineOrderFieldName="" AutoGenerateRouteId="true" AutoGenerateRouteName="false" ServiceLayerId="-1"><RouteFieldNames><NetworkFieldName Name="RouteId" FixedLength="0" IsFixedLength="true" IsPaddingEnabled="false" PaddingCharacter="32" PaddingPlace="None" IsPadNullValues="false" IsNullAllowed="false" AllowAnyLookupValue="true" LookupTableXml="" LookupTableName="" LookupKeyField="" LookupDisplayField=""/></RouteFieldNames><EventTables/><IntersectionClasses/><UnitsOfMeasure>3</UnitsOfMeasure><RoutePriorityRules/></Network></Networks><UtilityNetworkClasses/><FieldNames><CenterlineSequence ObjectId="ObjectId" RoadwayId="centerlineid" NetworkId="networkid" RouteId="routeid" FromDate="fromdate" ToDate="todate"/><CalibrationPoint ObjectId="ObjectId" Measure="measure" FromDate="fromdate" ToDate="todate" NetworkId="networkid" RouteId="routeid"/><Centerline ObjectId="ObjectId" RoadwayId="centerlineid"/><Redline ObjectId="ObjectId" FromMeasure="frommeasure" ToMeasure="tomeasure" RouteId="routeid" RouteName="routename" EffectiveDate="effectivedate" ActivityType="activitytype" NetworkId="networkid"/></FieldNames></Lrs>\n'
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
The domain was not found. [Yes_No]
The domain was not found. [UPDM_WeeksPerYear]
The domain was not found. [UPDM_DaysPerWeek]
The domain was not found. [Units_for_Volume]
The domain was not found. [Units_for_Surface_Area]
The domain was not found. [Units_for_Pressure]
The domain was not found. [Units_for_Length]
The domain was not found. [Units_for_Height]
The domain was not found. [Units_for_Heat]
The domain was not found. [Units_for_Flow]
The domain was not found. [Units_for_Diameter]
The domain was not found. [Units_for_Depth]
The domain was not found. [Symbol_Rotation]
The domain was not found. [Spatial_Accuracy]
The domain was not found. [Pipeline_Wellhead_Material_Class]
The domain was not found. [Pipeline_Wellhead_Diameter]
The domain was not found. [Pipeline_Wellhead_Connection_Type]
The domain was not found. [Pipeline_Weld_Joint_Coat_Type]
The domain was not found. [Pipeline_Valve_Status]
The domain was not found. [Pipeline_Valve_Remote_Failure_Type]
The domain was not found. [Pipeline_Valve_Position]
The domain was not found. [Pipeline_Valve_Model]
The domain was not found. [Pipeline_Valve_Manufacturer]
The domain was not found. [Pipeline_Valve_Key_Size]
The domain was not found. [Pipeline_Valve_Diameter]
The domain was not found. [Pipeline_Valve_DesignType]
The domain was not found. [Pipeline_Valve_Close_Direction]
The domain was not found. [Pipeline_Valve_Actuator_Type]
The domain was not found. [Pipeline_Transmission_Manufacturer]
The domain was not found. [Pipeline_Tee_DesignType]
The domain was not found. [Pipeline_Tap_DesignType]
The domain was not found. [Pipeline_Tank_Model]
The domain was not found. [Pipeline_Tank_Manufacturer]
The domain was not found. [Pipeline_Surface_Type]
The domain was not found. [Pipeline_Supplier]
The domain was not found. [Pipeline_Structure_Type]
The domain was not found. [Pipeline_Structure_Limited_Mobility]
The domain was not found. [Pipeline_Strainer_Model]
The domain was not found. [Pipeline_Strainer_Manufacturer]
The domain was not found. [Pipeline_Strainer_Device_Type]
The domain was not found. [Pipeline_Soil_Type]
The domain was not found. [Pipeline_Seam_Type]
The domain was not found. [Pipeline_Seam_Orientation]
The domain was not found. [Pipeline_Relief_Valve_DesignType]
The domain was not found. [Pipeline_Regulator_Type]
The domain was not found. [Pipeline_Regulator_Model]
The domain was not found. [Pipeline_Regulator_Manufacturer]
The domain was not found. [Pipeline_Regulator_Casing_Material]
The domain was not found. [Pipeline_Regulatory_Type]
The domain was not found. [Pipeline_Region]
The domain was not found. [Pipeline_Reducer_Fitting_Size]
The domain was not found. [Pipeline_Pressure_Test_Type]
The domain was not found. [Pipeline_Pressure_Test_Medium]
The domain was not found. [Pipeline_Pressure_Range]
The domain was not found. [Pipeline_Pipe_Wellhead_Pressure_Rating]
The domain was not found. [Pipeline_Pipe_Wall_Thickness-Transmission]
The domain was not found. [Pipeline_Pipe_Wall_Thickness-Station]
The domain was not found. [Pipeline_Pipe_Wall_Thickness-Riser]
The domain was not found. [Pipeline_Pipe_Wall_Thickness-Pressure_Sensor]
The domain was not found. [Pipeline_Pipe_Wall_Thickness]
The domain was not found. [Pipeline_Pipe_Test_Medium]
The domain was not found. [Pipeline_Pipe_Support_Model]
The domain was not found. [Pipeline_Pipe_Support_Material]
The domain was not found. [Pipeline_Pipe_Support_Manufacturer]
The domain was not found. [Pipeline_Pipe_Outside_Diameter-Transmission]
The domain was not found. [Pipeline_Pipe_Outside_Diameter-Station]
The domain was not found. [Pipeline_Pipe_Outside_Diameter-Riser]
The domain was not found. [Pipeline_Pipe_Outside_Diameter-Pressure_Sensor]
The domain was not found. [Pipeline_Pipe_Outside_Diameter]
The domain was not found. [Pipeline_Pipe_Diameter-Transmission]
The domain was not found. [Pipeline_Pipe_Diameter-Station]
The domain was not found. [Pipeline_Pipe_Diameter-Services]
The domain was not found. [Pipeline_Pipe_Diameter-Riser]
The domain was not found. [Pipeline_Pipe_Diameter-Pressure_Sensor]
The domain was not found. [Pipeline_Pipe_Diameter-Gathering]
The domain was not found. [Pipeline_Pipe_Diameter-Distribution]
The domain was not found. [Pipeline_Pipe_Diameter-Customer]
The domain was not found. [Pipeline_Pipe_Diameter-Combined]
The domain was not found. [Pipeline_Pipe_Crossing_Wired_Utility]
The domain was not found. [Pipeline_Pipe_Crossing_Transportation]
The domain was not found. [Pipeline_Pipe_Crossing_Topographic]
The domain was not found. [Pipeline_Pipe_Crossing_Pipe_Utility]
The domain was not found. [Pipeline_Pipe_Crossing_Location]
The domain was not found. [Pipeline_Pipe_Connection_Type]
The domain was not found. [Pipeline_Pipe_Condition]
The domain was not found. [Pipeline_Pipeline_Operator_Number]
The domain was not found. [Pipeline_PipeBend_DesignType]
The domain was not found. [Pipeline_Pilot_Connection_Type]
The domain was not found. [Pipeline_Pigging_Structure_Material]
The domain was not found. [Pipeline_Pass_Fail_Status]
The domain was not found. [Pipeline_Over_Pressure_Protection_Type]
The domain was not found. [Pipeline_Operator_Type]
The domain was not found. [Pipeline_On_Off_Status]
The domain was not found. [Pipeline_Odorizer_Model]
The domain was not found. [Pipeline_Odorizer_Manufacturer]
The domain was not found. [Pipeline_Odorant_Type]
The domain was not found. [Pipeline_Object_Status]
The domain was not found. [Pipeline_Muffler_Model]
The domain was not found. [Pipeline_Muffler_Material]
The domain was not found. [Pipeline_Muffler_Manufacturer]
The domain was not found. [Pipeline_Meter_Type]
The domain was not found. [Pipeline_Meter_Diameter-Customer]
The domain was not found. [Pipeline_Measurement_Units]
The domain was not found. [Pipeline_Measured_Length]
The domain was not found. [Pipeline_Marker_Markertype]
The domain was not found. [Pipeline_MAOP_Pressure_Estab_By]
The domain was not found. [Pipeline_Lining_Type]
The domain was not found. [Pipeline_Line_Valve_Connection]
The domain was not found. [Pipeline_Line_Heater_Model]
The domain was not found. [Pipeline_Line_Heater_Manufacturer]
The domain was not found. [Pipeline_Line_Design_Class]
The domain was not found. [Pipeline_Length_Source]
The domain was not found. [Pipeline_Leak_Work_Performed]
The domain was not found. [Pipeline_Leak_Survey_Type]
The domain was not found. [Pipeline_Leak_Survey_Status]
The domain was not found. [Pipeline_Leak_Survey_Method]
The domain was not found. [Pipeline_Leak_Survey_Frequency]
The domain was not found. [Pipeline_Leak_Repair_Type]
The domain was not found. [Pipeline_Leak_Method_Detected]
The domain was not found. [Pipeline_Leak_Location]
The domain was not found. [Pipeline_Leak_Inspect_Gas_In]
The domain was not found. [Pipeline_Leak_Inspect_Frequency]
The domain was not found. [Pipeline_Leak_Facility_Type]
The domain was not found. [Pipeline_Leak_Closed_Status]
The domain was not found. [Pipeline_Leak_Class]
The domain was not found. [Pipeline_Leak_Cause_Outside_Force]
The domain was not found. [Pipeline_Leak_Cause_Operations]
The domain was not found. [Pipeline_Leak_Cause_Natural]
The domain was not found. [Pipeline_Leak_Cause_Material]
The domain was not found. [Pipeline_Leak_Cause_Excavation]
The domain was not found. [Pipeline_Leak_Cause_Equipment]
The domain was not found. [Pipeline_Leak_Cause_Corrosion]
The domain was not found. [Pipeline_Junction_Pressure_Rating]
The domain was not found. [Pipeline_Junction_Material_Specification]
The domain was not found. [Pipeline_Junction_Diameter_Specification]
The domain was not found. [Pipeline_Junction_Angle]
The domain was not found. [Pipeline_Install_Method]
The domain was not found. [Pipeline_Inspection_Range_Type]
The domain was not found. [Pipeline_Inspection_Note_Type]
The domain was not found. [Pipeline_ILI_Survey_Type]
The domain was not found. [Pipeline_ILI_Survey_Marker_Type]
The domain was not found. [Pipeline_ILI_Survey_Int_Ext_Indicator]
The domain was not found. [Pipeline_Identified_Site_Outside]
The domain was not found. [Pipeline_Identified_Issue]
The domain was not found. [Pipeline_HCA_Provenance]
The domain was not found. [Pipeline_HCA_Area_Type]
The domain was not found. [Pipeline_Hanger_Model]
The domain was not found. [Pipeline_Hanger_Material]
The domain was not found. [Pipeline_Hanger_Manufacturer]
The domain was not found. [Pipeline_Girth_Weld_Type]
The domain was not found. [Pipeline_Flow]
The domain was not found. [Pipeline_Flange_DesignType]
The domain was not found. [Pipeline_Fitting_Diameter]
The domain was not found. [Pipeline_Excav_Equip_Causing_Damage]
The domain was not found. [Pipeline_Excav_Dam_Work_Type]
The domain was not found. [Pipeline_Excav_Dam_Root_Cause]
The domain was not found. [Pipeline_Excav_Dam_Resp_Party_Type]
The domain was not found. [Pipeline_Excav_Dam_Damage_Type]
The domain was not found. [Pipeline_Excav_Damage_Type]
The domain was not found. [Pipeline_End_Connection_Model]
The domain was not found. [Pipeline_End_Connection_Material]
The domain was not found. [Pipeline_End_Connection_Manufacturer]
The domain was not found. [Pipeline_EFV_Diameter]
The domain was not found. [Pipeline_Drip_Model]
The domain was not found. [Pipeline_Drip_Manufacturer]
The domain was not found. [Pipeline_DOT_Class_Type]
The domain was not found. [Pipeline_DOT_Class_Source]
The domain was not found. [Pipeline_Document_Type]
The domain was not found. [Pipeline_Document_Maturity_Index]
The domain was not found. [Pipeline_Device_Pressure_Rating]
The domain was not found. [Pipeline_Dehydration_Model]
The domain was not found. [Pipeline_Dehydration_Manufacturer]
The domain was not found. [Pipeline_DA_Survey_Type]
The domain was not found. [Pipeline_Could_Affect_Type]
The domain was not found. [Pipeline_Could_Affect_Intersection]
The domain was not found. [Pipeline_Corrosion_Extent]
The domain was not found. [Pipeline_Corrosion_Condition]
The domain was not found. [Pipeline_Cooling_Method]
The domain was not found. [Pipeline_Control_Line_Model]
The domain was not found. [Pipeline_Control_Line_Manufacturer]
The domain was not found. [Pipeline_Consequence_Area_Type]
The domain was not found. [Pipeline_Commodity_Type]
The domain was not found. [Pipeline_Coating_Type]
The domain was not found. [Pipeline_Coating_Condition]
The domain was not found. [Pipeline_Casing_Fill_Type]
The domain was not found. [Pipeline_Casing_Diameter]
The domain was not found. [Pipeline_ASTM_Valve_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_Transmission_Pipe_Type]
The domain was not found. [Pipeline_ASTM_Transmission_Pipe_Material]
The domain was not found. [Pipeline_ASTM_Transition_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_Tee_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_Strainer_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_Station_Pipe_Type]
The domain was not found. [Pipeline_ASTM_Station_Pipe_Material]
The domain was not found. [Pipeline_ASTM_Saddle_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_Riser_Pipe_Type]
The domain was not found. [Pipeline_ASTM_Riser_Pipe_Material]
The domain was not found. [Pipeline_ASTM_Regulator_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_Reducer_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_Pressure_Sensor_Pipe_Material]
The domain was not found. [Pipeline_ASTM_Pipe_Material]
The domain was not found. [Pipeline_ASTM_Pipe_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_Meter_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_Material]
The domain was not found. [Pipeline_ASTM_Manufacturer]
The domain was not found. [Pipeline_ASTM_End_Cap_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_Elbow_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_EFV_Manufacture_Component]
The domain was not found. [Pipeline_ASTM_Coupling_Manufacture_Component]
The domain was not found. [Pipeline_Anomaly_Type]
The domain was not found. [Pipeline_Anomaly_Status]
The domain was not found. [Pipeline_Anomaly_Severity]
The domain was not found. [Pipeline_Anomaly_Remediation]
The domain was not found. [Pipeline_Anomaly_Priority]
The domain was not found. [Pipeline_Anchor_Model]
The domain was not found. [Pipeline_Anchor_Material]
The domain was not found. [Pipeline_Anchor_Manufacturer]
The domain was not found. [Pipeline_Alignment_Sheet_Type]
The domain was not found. [Network_5_UnknownAssetType]
The domain was not found. [Lifecycle_Status]
The domain was not found. [Lifecycle_Combined]
The domain was not found. [Gas_Valve_Condition]
The domain was not found. [dReferentMethod]
The domain was not found. [dLRSNetworks]
The domain was not found. [dActivityType]
The domain was not found. [CP_Wire_Gauge]
The domain was not found. [CP_Test_Point_Wire_Count]
The domain was not found. [CP_Rectifier_Manufacturer]
The domain was not found. [CP_ASTM_Anode_Manufacture_Component]
The domain was not found. [CP_Anode_Weight]
The domain was not found. [CP_Anode_Material]
The domain was not found. [CP_Anode_Manufacturer]
The domain was not found. [Bonded_Insulated]
The domain was not found. [Asset_Type_Structure_Junction_Pipe_Access_Point]
The domain was not found. [Asset_Type_Structure_Boundary_Pipeline_Pipe_Vault]
The domain was not found. [Asset_Type_Pipeline_Structure_Line_Casing]
The domain was not found. [Asset_Type_Pipeline_Structure_Junction_Vault]
The domain was not found. [Asset_Type_Pipeline_Structure_Junction_Valve_Box]
The domain was not found. [Asset_Type_Pipeline_Structure_Junction_Sleeve]
The domain was not found. [Asset_Type_Pipeline_Structure_Junction_Pipe_Support]
The domain was not found. [Asset_Type_Pipeline_Structure_Junction_Pipe_Hanger]
The domain was not found. [Asset_Type_Pipeline_Structure_Junction_Muffler]
The domain was not found. [Asset_Type_Pipeline_Structure_Junction_End_Connection]
The domain was not found. [Asset_Type_Pipeline_Structure_Junction_Anchor]
The domain was not found. [Asset_Type_Pipeline_Structure_Boundary_Station_Structure]
The domain was not found. [Asset_Type_Pipeline_Structure_Boundary_Processing_Facility]
The domain was not found. [Asset_Type_Pipeline_Structure_Boundary_Cathodic]
The domain was not found. [Asset_Type_Pipeline_Line_Transmission_Pipe]
The domain was not found. [Asset_Type_Pipeline_Line_Test_Lead_Wire]
The domain was not found. [Asset_Type_Pipeline_Line_Storage_Pipe]
The domain was not found. [Asset_Type_Pipeline_Line_Station_Pipe]
The domain was not found. [Asset_Type_Pipeline_Line_Service_Pipe]
The domain was not found. [Asset_Type_Pipeline_Line_Riser_Pipe]
The domain was not found. [Asset_Type_Pipeline_Line_Pressure_Sensor_Pipe]
The domain was not found. [Asset_Type_Pipeline_Line_Linear_Anode]
The domain was not found. [Asset_Type_Pipeline_Line_Gathering_Pipe]
The domain was not found. [Asset_Type_Pipeline_Line_Distribution_Pipe]
The domain was not found. [Asset_Type_Pipeline_Line_Customer_Pipe]
The domain was not found. [Asset_Type_Pipeline_Line_CP_Cable]
The domain was not found. [Asset_Type_Pipeline_Line_Bonding_Line]
The domain was not found. [Asset_Type_Pipeline_Line_AC_Mitigation_Wire]
The domain was not found. [Asset_Type_Pipeline_Junction_Wire_Junction]
The domain was not found. [Asset_Type_Pipeline_Junction_Weld]
The domain was not found. [Asset_Type_Pipeline_Junction_Union]
The domain was not found. [Asset_Type_Pipeline_Junction_Transition]
The domain was not found. [Asset_Type_Pipeline_Junction_Tee]
The domain was not found. [Asset_Type_Pipeline_Junction_Tap]
The domain was not found. [Asset_Type_Pipeline_Junction_Tank]
The domain was not found. [Asset_Type_Pipeline_Junction_Screw]
The domain was not found. [Asset_Type_Pipeline_Junction_Saddle]
The domain was not found. [Asset_Type_Pipeline_Junction_Reducer]
The domain was not found. [Asset_Type_Pipeline_Junction_Plug]
The domain was not found. [Asset_Type_Pipeline_Junction_Plastic_Fusion]
The domain was not found. [Asset_Type_Pipeline_Junction_Pipe_Bend]
The domain was not found. [Asset_Type_Pipeline_Junction_Odorizer]
The domain was not found. [Asset_Type_Pipeline_Junction_Line_Heater]
The domain was not found. [Asset_Type_Pipeline_Junction_Insulation_Junction]
The domain was not found. [Asset_Type_Pipeline_Junction_Flange]
The domain was not found. [Asset_Type_Pipeline_Junction_Expansion_Joint]
The domain was not found. [Asset_Type_Pipeline_Junction_End_Cap]
The domain was not found. [Asset_Type_Pipeline_Junction_Electro_Stop]
The domain was not found. [Asset_Type_Pipeline_Junction_Elbow]
The domain was not found. [Asset_Type_Pipeline_Junction_Drip]
The domain was not found. [Asset_Type_Pipeline_Junction_Dehydration_Equipment]
The domain was not found. [Asset_Type_Pipeline_Junction_Coupon]
The domain was not found. [Asset_Type_Pipeline_Junction_Coupling]
The domain was not found. [Asset_Type_Pipeline_Junction_Cooling_System]
The domain was not found. [Asset_Type_Pipeline_Junction_Connection_Point]
The domain was not found. [Asset_Type_Pipeline_Device_Wellhead_Source_Flange]
The domain was not found. [Asset_Type_Pipeline_Device_Test_Point]
The domain was not found. [Asset_Type_Pipeline_Device_Strainer]
The domain was not found. [Asset_Type_Pipeline_Device_Scrubber]
The domain was not found. [Asset_Type_Pipeline_Device_Relief_Valve]
The domain was not found. [Asset_Type_Pipeline_Device_Regulator]
The domain was not found. [Asset_Type_Pipeline_Device_Rectifier]
The domain was not found. [Asset_Type_Pipeline_Device_Pump]
The domain was not found. [Asset_Type_Pipeline_Device_Pressure_Monitoring_Device]
The domain was not found. [Asset_Type_Pipeline_Device_Meter]
The domain was not found. [Asset_Type_Pipeline_Device_Line_Stopper]
The domain was not found. [Asset_Type_Pipeline_Device_Lamp]
The domain was not found. [Asset_Type_Pipeline_Device_Grounding_Point]
The domain was not found. [Asset_Type_Pipeline_Device_Flow_Valve]
The domain was not found. [Asset_Type_Pipeline_Device_Excess_Flow_Valve]
The domain was not found. [Asset_Type_Pipeline_Device_Decoupler]
The domain was not found. [Asset_Type_Pipeline_Device_Controllable_Valve]
The domain was not found. [Asset_Type_Pipeline_Device_Controllable_Tee]
The domain was not found. [Asset_Type_Pipeline_Device_Compressor]
The domain was not found. [Asset_Type_Pipeline_Device_Anode]
The domain was not found. [Asset_Type_Pipeline_Assembly_Wellhead]
The domain was not found. [Asset_Type_Pipeline_Assembly_Valve_Assembly]
The domain was not found. [Asset_Type_Pipeline_Assembly_Town_Border_Station]
The domain was not found. [Asset_Type_Pipeline_Assembly_Rural_Tap]
The domain was not found. [Asset_Type_Pipeline_Assembly_Regulator_Station]
The domain was not found. [Asset_Type_Pipeline_Assembly_Pump_Station]
The domain was not found. [Asset_Type_Pipeline_Assembly_Pigging_Structure]
The domain was not found. [Asset_Type_Pipeline_Assembly_Meter_Setting]
The domain was not found. [Asset_Type_Pipeline_Assembly_Fitting_Assembly]
The domain was not found. [Asset_Type_Pipeline_Assembly_Compressor_Station]
The domain was not found. [Asset_Type_Pipeline_Assembly_Cathodic_Assembly]
The domain was not found. [Asset_Owner]
The domain was not found. [Asset_Manager]
Failed to execute (ImportXMLWorkspaceDocument).
Failed script Change GDB Spatial Reference...
Failed to execute (ChangeGDBSpatialReference).
Failed at Wednesday, July 19, 2023 3:37:03 PM (Elapsed Time: 4 minutes 57 seconds)
What should I do to avoid this error and been able to create this geodatabase?
JSchroeder
Verification, but still important - I believe the version of Pro you are using is a typo, I'm assuming you are using Pro 3.1.2, not 3.2.1...
Can you try outputting the GDB to a local drive vs network?
Finally, it appears you have a typo in the Z Tolerance. Please verify, but it should be .001 instead of .0001.
I was able to run the tool successfully even using the incorrect Z tolerance, so I might prioritize running the output GDB locally vs to the network - this is a lot of data to be writing across the network.
JSchroeder
Hi @Cristian_Galindo, can you verify that you are using Pro 3.1? In this version of the solution, we are supporting both Enterprise 10.9.1 (Pro 2.9) and 11.1 (Pro 3.1). It appears that you are using the UtilityDataManagementSupport_3.1 toolbox, which requires Pro 3.1.
I do not know if this would cause an issue, but is your "U" drive local or a network drive?
Cristian_Galindo
hello,
I am using ArcGIS Pro 3.2.1. My U: drive is network drive
AyanPalit
@Cristian_Galindo Thanks for using the Pipeline Referencing Foundation
Few suggestions:
  1. Input Geodatabase 'UPDM_PipelineReferencing.gdb' has APR configured using ArcGIS Pro 3.1. Check if you are using Pro 3.1 with Location Referencing extension.
  2. Avoid special characters like '.' in output GDB nomenclature.
Ayan Palit | Principal Consultant Esri
Cristian_Galindo
Hello Ayan,
    1. I am using ArcGIS Pro 3.2.1 and have the location referencin extension licensed
    1. I thought about that , and already tried using '_', the result was the same
JSchroeder
Cristian_Galindo
Hello,
you are correct, I made those typo 😞
I changed the project to the local drive, and corrected the Z tolerance.
Now the process has finished.
Thanks for the assistance
