Modify Route FromDate without deleting
1332
12-15-2022 12:10 PM
AndrewLaux
If a route has been added to the LRS with an incorrect FromDate, is it possible to modify this date attribute for the route and associated calibration points/events?
When attempting to modify this route attribute in the attribute table for ArcGIS Pro, the error is returned:
ERROR: Unable to complete operation., Only Location Referencing tools can be used to edit this feature/field.
Is the only option to delete the route with incorrect FromDate and reload all of the events?
AyanPalit
@AndrewLaux FromDate/ToDate are APR managed fields and cannot be updated manually; this is important for data integrity and keep routes, calibration points, associated events in sync. Hence, the error returned when modifying APR reserved fields is as-designed and expected.
Reference: LRS data model
The best practice is to perform versioned editing and QA/QC before posting edits.  If this is not a production/versioned environment, it would be best to delete and reload.
Ayan Palit | Principal Consultant Esri
HazelRiordan
ENH-000179769 addresses this issue.
