Attributing events to multiple routes?
1744
12-19-2022 05:20 AM
Jol1234
Is it possible to attribute a single point event to multiple routes? For example if I want to attribute a traffic signal control box to two roads which are separate events how would I go about doing this?
Thank you
AyanPalit
@Jol1234 Depending on the situation, there are multiple ways to handle this situation. Suggest reviewing the following resources, test the option that best applies to your use case.
Ayan Palit | Principal Consultant Esri
Jol1234
Thank you @AyanPalit,
I was hoping you could elaborate on if route dominance could apply to point events as well as linear ones? Also your bullet point about "Event attributes can be extended to capture secondary route and measure"
Would that just involve having an extra column in the event table for "secondary route"?
Thank you
AyanPalit
  • Route Dominance rules are configured at the Network Route level and applies to both point and linear events.
  • Second option, is at the Network Event level. Extending the Event Attributes may look like:
Primary RoutePrimary MeasureSecondary RouteSecondary Measure
R1100S150
R2200S2150
