When entering distances in a traverse, why does the measurement of the graphic line not equal the distance entered in the table? Nothing matches up when I enter it.
1111
01-10-2019 02:01 PM
AngelaParker1
I am inputting direction-distance information into the traverse window.  I enter a distance, but when I see the line it doesn't match up where it should with other layers and when I measure it with the measure tool it is not the same distance that I entered into the traverse window.
DanPatterson_Retired
you wouldn't have been using a Web Mercator coordinate system would you?
if so, you shouldn't do measurements on maps using it, unless you know that the distances are corrected... which they usually aren't
