Traverse tool will not work with connection lines
9133
10
10-28-2022 12:27 PM
AngelaP
I've run into a problem when trying to COGO in a connection line using the Traverse tool.
I can see the start point and end point as red squares, but not the connecting lines. I can enter in a perfect square as a test and see that the misclosure is 0, and there is a calculated area, but I cannot see the sketch, finish the sketch, or save the edits.
I tried to export the traverse to a text file. Opening the file in Notepad reveals that each distance and direction has been saved as "???" and of course importing that text file does not work.
I can use the Traverse tool to enter in lot and parcel lines just fine. Is there something about connection lines that I'm missing?
ChristineLeslie
Hi
I tested this out with a subtype on the 3.0 install (no patches) and I couldnt reproduce the problem. I thought the issue may be the subtype.
One question - can you create connection lines using the Create pane and a feature template - and do you see this warning? This may be causing your issue...
Christine
