Traverse Polygon
11188
23
08-09-2017 08:52 AM
RickyReid
It appears that we only have the ability to traverse lines in Pro 2.0.  It would be extremely helpful to be able to traverse a polygon.  Is there another tool I'm perhaps missing?
Tags (1)
DanPatterson_Retired
is the polygon perimeter (line) not sufficient?
RickyReid
Unfortunately no.  I need to be able to traverse a polygon.  This functionality was available in ArcMap.
It didn't even get a mention on this list unavailable tools in Pro unless I am blind, it is elsewhere, or it was forgotten
RickyReid
Well the tool itself is in Pro, but now it is specific to polylines only.
yes... but there is no mention of a functionality change, which should have been indicated... so it is either an omission in documentation or they just haven't gotten around to it.  It might be worth a buzz to tech support so they can pass it on to the Pro dev team
by Anonymous User
Not applicable
The ability to traverse a polygon layer will be added in a future release.
Thanks Sean
mhoffman6
Sean,
I posted about COGO polygons for easements and other areas that require legal descriptions. Do you know when this will be released? This is pretty crucial for small local governments that track their utility, right of way, and pathway easements such as the city I currently work for. The sooner we are able to test this out and see the functionality the better it will be for us to train the other GIS individuals of our city.
Here is the link to my question and concern. https://community.esri.com/ideas/13861-add-full-cogo-functionality-to-arcgis-pro
by Anonymous User
Not applicable
Hi Matthew,
Polygon traverse will be available post 2.1
The construct polygons command will be available at 2.1, meaning features can be traversed as lines then converted to polygons as required.
