Parcel Fabric - Reconstruct from seeds vs Build Extent
1399
09-18-2024 05:48 AM
VassilisTrigkas1974
Hi, I want to ask about the differences between "Reconstruct From Seeds" and "Build Extent."
I know that "Reconstruct From Seeds" can be used to rebuild a polygon from Shrink to Seeds, but I believe you can do something similar with "Build Extent."
What exactly is the difference between these two tools?
TimHodson
Hi @VassilisTrigkas1974
After shrinking parcels to seeds one or more of the lines bounding a seed may not belong to the same record as that seed. In these circumstances the regular Build functions will not re-build those seeds. The Reconstruct From Seeds command is used for these cases, and will create the parcel polygon even when there is a loop of lines that come from different records.
-Tim
TimHodson
-Tim
VassilisTrigkas1974
Hi @TimHodson, thank you very much  for your reply.
