Parcel alignment failed in parcel fabric
1667
07-02-2024 09:35 PM
DevakalaiselvanS
Arcgis pro 3.3.1 .i need your support to solve this
AmirBar-Maor
It looks like the parcel you are trying to align is:
  1. The parcel polygon does not coincide with the parcel lines and points
  2. The parcel is placed very far from where it should be
  3. It is not clear what kind of transaction/workflow is behind it
If you think you've found a bug, please contact technical support.
I would try to:
  1. Use the move tool to move and rotate the parcel to where it should be. You can also try to use 'Shring to seed' and then ' Reconstruct from Seed' to fix it.
  2. Make sure the parcel is correct = The polygon has lines and points defining it
AmirBar-Maor
I would try to:
DevakalaiselvanS
thank you for your support
