So I haven't been able to find a solution to this, and of course there's a good chance I'm missing something, but is there a line-string tool as there was in ArcMap to create parcel boundaries along natural features. I'm in Minnesota and have multiple parcels that border up against lakes and rivers? Thanks in advance for any assistance.
Hi Ross
Here is how you would traverse/digitize in a natural boundary when using the traverse tool to create a new parcel:
I have attached a screenshot of the traverse - it has two natural boundaries in it.
If you are not using the Traverse tool - you can also just switch to the regular polyline tool to digitize in a parcel boundary - as Frank mentioned.
Hope this helps
Christine
Hi Ross
Hope this helps
Christine
Thanks, Christine, this is a much better explanation than I provided.
Frank Conkling - Panda Consulting
Thank you (and Frank) for answering my question. I have a follow-up question; is there a way to define a line as a natural boundary after-the-fact. For example, if I import a bunch of parcels to my new Pro Parcel Fabric, can I set lines to this after they've been imported? Thanks!
Thank you Frank and Christine, exactly the information I was looking for (and right under my nose as I suspected!) This answers my question, thanks!
Ross, In the Parcel Fabric converting 2-point lines to a line-string is simple. Select the lines to convert to a line-string, execute merge (being sure to uncheck keep original features) and merge into an existing line. The result will be a line-string.
Good luck,
Frank is correct - just use the standard editing Merge tool to merge lines into a polyline. Be aware that you may lose COGO attributes if you entered them for the individual lines.
