Default COGO labeling expressions - getting COGO ERROR label
1508
02-07-2025 01:56 PM
RobertChaney
I have a parcel fabric where the COGO field values are in meters.  I'm able to modify the Default COGO label expression: var cogo_distance = $feature.Distance * 3.28084;
Which gives me the proper label in feet.  However, for lines with values in the ArcLength field, the COGO ERROR label shows.  When I attempt to change the variable in the default COGO expression to the following:
var cogo_arclength = $feature.ArcLength * 3.28084;
I get COGO ERROR labels on all lines.
If I take off the conversion for the Distance field, the ArcLength shows properly, but of course the Distance field shows the COGO ERROR.
Can anyone help point out where I need to further modify the expression to get both fields to show properly in feet?
Robert.
Pro ver. 3.3.1
geodatabase is fgdb
Parcel Fabric ver. 5
// Change the settings portion to configure direction format, color, rounding and abbreviations
// This is an Arcade expression
// SETTINGS
var ShowDistance = true;   //set as 'true' to show distance
var ShowDirection = false;  //set as 'true' to show direction
var DirectionType = 1; // 1 = Quadrant Bearing; 2 = North Azimuth; 3 = South Azimuth
var ShowRadius = false;     //set as 'true' to show radius
var ShowCurveParameter = true;    //set as 'true' to show a curve parameter
var ShowCOGOType = true;  //set as 'true' to show prefixes and postfixes defined below for each cogo line label
var COGOType_Entered = ['', ''] //Change prefix and postfix for Entered courses
var COGOType_Computed = ['±', '']  //Change prefix and postfix for Computed courses
var COGOType_FromGeom = ['<', '>'] //Change for prefix and postfix From Geometry courses. The < is a special character to represent the left angle bracket
var CurveParameter = "ArcLength"; //set as 'ArcLength' or 'Chord' or 'Angle' for central angle. Case sensitive!
var ErrorString = "COGO ERROR";   //set to display invalid COGO combinations
var RadiusAbbr = 'R=';     //radius abbreviation
var Radius2Abbr = 'R2=';     //radius2 abbreviation for spiral curves
var ArclengthAbrr = '';  //arclength abbreviation
var ChordAbbr = 'C=';      //chord abbreviation
var AngleAbbr = 'A=';      //central Angle abbreviation
var DistUnitRounding = 2;  //number of decimal places for distance units: distance, radius, arclength & chord
var NumberFormat = "#,###.00" //number format. In this example: thousands separator with padding of 2 zeros
var directionColor = "blue='255'"; //direction color: red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var distanceColor = "black='255'"; //distance color: red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var radiusColor = "blue='255'";    //radius color:  red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var curveParamColor = "black='255'"; //curve parameter color:  red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var partialCOGOColor = "magenta='255'"; //partial COGO color: red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var invalidCOGOColor = "red='255'"; //invalid COGO color: red, green, blue, cyan, magenta, yellow, black. You can also use RGB or CYMK combinations.
var fontNameSize = "<FNT name = 'Arial' size = '10'>"; //font type and size
// VARIABLES
var cogo_direction = $feature.Direction;
var cogo_radius = $feature.Radius;
var cogo_radius2 = $feature.Radius2
var cogotype = $feature.COGOType
if (HasKey($feature, "labelPosition")){
   var labelPosition = $feature.labelPosition
else {
   var labelPosition = 1
var binaryDictionary; //binary dictionary to check COGO combinations
var checksum = 0; //initialize checksum
var validValuesArray; //array of valid values for COGO combinations
var partialValuesArray; //array of partial values for COGO
var directionStr = ""; //direction string using for label
var distanceStr = "";  //distance string using for label
var radiusStr = "";    //radius string using for label
var radius2Str = "";    //radius2 string using for labeling spiral curves
var curveStr = "";     //curve parameter string using for label
var prefixPostfix = ['', '']  //Used for prefix and postfix of COGO Type
var angleRad; //curve angle in radians
var COGOValidity; //COGO combinations validity. can be valid, partial or invalid.
if (IsEmpty(cogo_direction) && IsEmpty(cogo_distance) && IsEmpty(cogo_radius) && IsEmpty(cogo_radius2) && IsEmpty(cogo_arclength)){
    return ""
function NorthAzimuth2Quadbearing(azimuth){
    return ConvertDirection(azimuth, {directionType:'North', angleType: 'Degrees'}, {directionType:'Quadrant', angleType: 'DMS', outputType: 'text', format: 'pd[°]mm[\']ss["]b'})
function DMS_North(azimuth){
    return ConvertDirection(azimuth, {directionType:'North', angleType: 'Degrees'}, {directionType:'North', angleType: 'DMS', outputType: 'text', format: 'd[°]mm[\']ss["]'})
function DMS_South(azimuth){
    return ConvertDirection(azimuth, {directionType:'North', angleType: 'Degrees'}, {directionType:'South', angleType: 'DMS', outputType: 'text', format: 'd[°]mm[\']ss["]'})
function IsValidCOGO(cogo_direction, cogo_distance, cogo_radius, cogo_arclength, cogo_radius2) {
    binaryDictionary= Dictionary('dir', 1, 'dist',2, 'rad',4, 'arc',8, 'rad2',16)
    if (!IsEmpty(cogo_direction)) {checksum+=binaryDictionary.dir}
    if (!IsEmpty(cogo_distance)) {checksum+=binaryDictionary.dist}
    if (!IsEmpty(cogo_radius)) {checksum+=binaryDictionary.rad}
    if (!IsEmpty(cogo_arclength)) {checksum+=binaryDictionary.arc}
    if (!IsEmpty(cogo_radius2)) {checksum+=binaryDictionary.rad2}
    validValuesArray=[0,3,13,29]; //array of valid combinations: '0' for nothing, ... '13' for direction & radius & arclength ...
    partialValuesArray=[1,2,4,5,8,9,12,16,17,20,21,24,25,27,28]; //array of partial combinations: '1' for only direction, '2' for only distance, '4' for only radius...
    //Invalid Values = [6,7,10,11,14,15,18,19,22,23,26,30,31]
    if (IndexOf(validValuesArray,checksum)>-1) { // a negative value is returned if checksum value is not in the a valid combination array
        return "valid";
    if (IndexOf(partialValuesArray,checksum)>-1){
        return "partial";
    return "invalid";
function COGOTypePrefixPostfix(cogotypeValue){
    if (ShowCOGOType){
        if (cogotypeValue == 1) { //Entered
           return COGOType_Entered
        else if(cogotypeValue == 2) { //From Geometry
           return COGOType_FromGeom
        else if(cogotypeValue == 3) { //Computed
           return COGOType_Computed
        else { //If not set or invalid value
           return ['', '']
    else{
       return(['', ''])
COGOValidity = IsValidCOGO(cogo_direction, cogo_distance, cogo_radius, cogo_arclength, cogo_radius2);
if ( COGOValidity == "invalid") { //if invalid COGO return error string
    return "<BOL><CLR " + invalidCOGOColor + ">" + fontNameSize + ErrorString + "</FNT></CLR></BOL>";
else if (COGOValidity == "partial") { //if a partial COGO change colors
    distanceColor = partialCOGOColor;
    directionColor = partialCOGOColor;
    radiusColor = partialCOGOColor;
    curveParamColor = partialCOGOColor;
// Direction string
if (ShowDirection) {
    if (IsEmpty(cogo_direction)==false) {
        if (DirectionType == 1) {  //using quadrant bearing format
            directionStr = NorthAzimuth2Quadbearing(cogo_direction);
        else if (DirectionType == 2) {  //using north azimuth format
            directionStr = DMS_North(cogo_direction);
        else if (DirectionType == 3) { //using south azimuth format
            directionStr = DMS_South(cogo_direction);
// Distance string
if (ShowDistance) {
    if (IsEmpty(cogo_distance)==false) {
    distanceStr = text(round(cogo_distance,DistUnitRounding), NumberFormat);
//Radius String
if (ShowRadius) {
    if (!IsEmpty(cogo_radius)) { //it can be a curve or a spiral
        if (IsEmpty(cogo_radius2)) { //if radius2 is empty this is a curve
            radiusStr = RadiusAbbr + " " + text(round(cogo_radius, DistUnitRounding), NumberFormat);
        else { // it is a spiral
            radiusStr = RadiusAbbr + " " + text(round(cogo_radius, DistUnitRounding),NumberFormat);
            radius2Str = Radius2Abbr + " " + text(round(cogo_radius2, DistUnitRounding),NumberFormat);
            if (cogo_radius == 0) { //substitute to infinity sign
                radiusStr = RadiusAbbr + " ∞ ";
            if (cogo_radius2 == 0) { //substitute to infinity sign
                radius2Str = Radius2Abbr + " ∞ ";
// Curve Parameter
if (ShowCurveParameter) {
            if (CurveParameter == 'ArcLength') {
                curveStr = text(round(cogo_arclength, DistUnitRounding), NumberFormat); //return Arc length
            angleRad = cogo_arclength/(abs(cogo_radius)) //calculate angle in radians
            if (CurveParameter == 'Angle') {
                curveStr = DMS_North(angleRad * 180 / pi); // convert radian to degrees and show as DMS
            if (CurveParameter == 'Chord') {
                curveStr = text(round((2 * abs(cogo_radius) * Sin(angleRad/2)),DistUnitRounding), NumberFormat); //calculate chord length
//Determine type of curve displayed
var CurveTypePrefix = ""
if (!IsEmpty(curveStr)){
    if (CurveParameter == 'ArcLength'){
        CurveTypePrefix = ArclengthAbrr
    else if (CurveParameter == 'Angle'){
        CurveTypePrefix = AngleAbbr
    else if (CurveParameter == 'Chord'){
        CurveTypePrefix = ChordAbbr
var isStraightLine = IsEmpty(radiusStr) && IsEmpty(radius2Str) && IsEmpty(curveStr)
// Assemble label string
//Get prefix and postfix if either distance or curve is not empty. NOTE If both aren't empty it's invalid COGO
if (!IsEmpty(distanceStr) || !IsEmpty(curveStr)){
    prefixPostfix = COGOTypePrefixPostfix(cogotype)
var sharedLabelBuffer = ""
if (labelPosition == 3) {
    sharedLabelBuffer = " \n"
//Straight lines
if (isStraightLine){
    if (!IsEmpty(directionStr) && !IsEmpty(distanceStr)){ //If Direction and Distance are both NOT Empty
        return fontNameSize + "<CLR " + directionColor + ">" + directionStr  + "</CLR>" + "\n" +
                              "<CLR " + distanceColor + ">" + prefixPostfix[0] + distanceStr + prefixPostfix[1] + "</CLR></FNT>";
    else if (IsEmpty(directionStr)){  //If Direction is empty
        return fontNameSize + sharedLabelBuffer + "<CLR " + distanceColor + ">" +
    else{  //If Distance is empty
        return fontNameSize + sharedLabelBuffer + "<CLR " + directionColor + ">" + directionStr +  "</CLR></FNT>";
//Curves
//If one or both radii and the curve string are NOT empty show the full curve
if ((!IsEmpty(radiusStr) || !IsEmpty(radius2Str)) && !IsEmpty(curveStr)){
    return fontNameSize + "<CLR " + radiusColor + ">" + radiusStr + "</CLR>" + " " +
                          "<CLR " + radiusColor + ">" + radius2Str + "</CLR>" + "\n" +
                          "<CLR " + curveParamColor + ">" + CurveTypePrefix + ' ' +
                          prefixPostfix[0] + curveStr + prefixPostfix[1] + "</CLR></FNT>";
//If the curve is empty
else if (IsEmpty(curveStr)){
    return fontNameSize + sharedLabelBuffer + "<CLR " + radiusColor + ">" + radiusStr + "</CLR>" + "  " +
                          "<CLR " + radiusColor + ">" + radius2Str + "</CLR></FNT>"
//If both radius are empty
else{
    return fontNameSize + sharedLabelBuffer + "<CLR " + curveParamColor + ">" + CurveTypePrefix + ' ' +
AmirBar-Maor
Hello @RobertChaney
A "COGO Error" is returned when there are too many parameters. For example, if Direction, Distance, and Radius are all populated.
It looks like the conversion is placing a zero ('0') if the original value is NULL, instead of keeping it empty.
This can be solved by checking and only converting the units if the attribute is not empty:
if (!IsEmpty($feature.Distance)) cogo_distance = cogo_distance*3.28084;
Add this check for any value that you convert (distance, radius, arclength, radius2)
Please let us know if this solves the issue
AmirBar-Maor
Hello @RobertChaney
RobertChaney
Your expression solved the issue, thanks Amir.
Robert.
