Curve going wrong way in traverse
3550
02-22-2022 12:47 PM
CarbonAmerica
Hi everyone,
I am trying to map an access easement on ArcPro and I'm having some difficulty getting the curve to behave correctly. The curve data is as follows:
Delta  = 98-53-00. R=165, Arc = 284.76, CH= S41-39-35W 250.72
I type in S41-39-35W cb, leave distance blank, 165 for radius, and 250.72 for chord length. However, the curve is going the wrong way. If you look at the screen grab below, it's supposed to follow  the curve of County Road 32. Any idea why this would be happening?
Thanks!
Thanks so much
jcarlson
Negative values in the radius column will create a curve to the left.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
by Anonymous User
Not applicable
What's the best way in ArcPro to draw a curve with the information given in this legal?
THENCE SOUTH 03°33'15" EAST 94.04 FEET TO A POINT ON A CURVE TO THE LEFT, THE
RADIUS POINT BEING AN IRRIGATION PIVOT WHICH BEARS NORTH 86°26'45" EAST 1318.52
FEET:
THENCE EASTERLY ALONG SAID CURVE 4017.93 FEET:
