Create Point at Absolute X, Y only sometimes populates X and Y fields
1202
08-31-2025 06:56 PM
Jessica_Watson
Hello,
We are working in parcel fabric and creating points at an absolute X and Y location using a Feature Template.
When testing this, I am using the same steps as the below link:
Specify an exact x,y,z location—ArcGIS Pro | Documentation
I first click Create Features > Points template. I then right clicking on the map > Absolute X, Y, Z > enter the relevant coordinates and press Enter.
I am working in metres and MGA coordinate systems and have the map settings and zone configured accordingly. I set my map to the relevant coordinate system before beginning and enter the coordinates like this.
This works really well, sometimes and the X and Y attribute fields are populated well.
However, maybe 30 percent of the time, the X and Y attribute fields will not be populated from the Absolute X, Y, Z tool.
I was wondering if there is an issue with the tool or if there is a setting we are missing that can ensure that the X, Y value comes across to the X, Y attribute fields every time?
Any suggestions would be much appreciated.
Jessica
AmirBar-Maor
Hello @Jessica_Watson
We have noticed it as well and are working to fix it as part of ArcGIS Pro 3.6. As you have mentioned - it is not easy to consistently reproduce.
Regardless, we recommend opening a case with technical support.
Jessica_Watson
Hi @AmirBar-Maor ,
Thanks for the quick response. What is the best method to open a case with technical support? Is there an email address?
Thanks
Jessica
AmirBar-Maor
@Jessica_Watson This 1-minute video shows the process:
https://youtu.be/o3mxHG9070s?si=g_nkIxMnn_XuLX5E
This video provides Authorized Callers for their organization on My Esri portal with step-by-step instructions on how to submit a request for technical support. #MyEsri
AmirBar-Maor
AmirBar-Maor
@Jessica_Watson The issue has been fixed as part of ArcGIS Pro 3.6.
