Build parcel geometry error
1651
10-22-2020 02:04 PM
WileyBogren
Hello!
I'm troubleshooting a migration workflow, to bring parcel data from a points-and-lines model into Parcel Fabric (v3, Pro 2.6).
The migration on my last test run failed to build a dozen or less seeds out of almost 500k parcels.  I tried to resolve these using 'Build Extent' while limiting the extent to the failed (seed) parcels, something that successfully resolves some other types of migration errors. In this case, I got a new error, shown in the attached image:
Build Parcel Fabric
Edit operation failed.
The geometry is legal but certain of its properties cannot be computed.
Has anyone experienced, or even better, resolved this issue before?
Thank you!
Wiley
AmirBar-Maor
Hi Wiley,
I recommend that you submit a technical support case.
It is always a good practice to run the geoprocessing "Check Geometry" and/or "Repair Geometry".
Amir
