ArcGIS Pro - Traverse - Arc Direction
1764
11-26-2018 03:47 PM
NathanDuncan
Hey,
I'm using the Modify Features - Traverse tool to enter in a subdivision and I'm having trouble drawing arcs. The direction of the arcs on our plans always refer to the bearing from the start point to the end point. When entering this bearing in to the tool it appears to use it as the tangent direction of the arc - refer to images below.
Is there a way to change this behaviour?
Thanks in advance.
Supplied plan/desired result
Data entered
Result
Tags (3)
KoryKramer
Esri Esteemed Contributor
Maybe somebody in the Land Records‌ group could take a look.
AmirBar-Maor
@NathanDuncan
Upgade to a recent release. You can set it to Chord
