Ground to Grid
1652
08-01-2022 12:17 PM
Status: In Product Plan
Syvertson
When ready to create a traverse that has a ground to grid correction required, the process is to hover over the icon, and then select one of the two options:  1) Enter the ground direction and distance and then draw it, or 2) draw the ground line and grid line.
I would like to add a third option:  3) Select line with appropriate grid correction already applied.
Not sure if wording is good, but what I mean is that if I have a line with good cogo and positioning already, I should be able to have the program determine the correct ground to grid correction that would make the cogo line I selected work.
2 Comments
SamMontoia1
It would be really helpful to return to a ground to grid correction value from a feature or set of features.  Maybe also having a ground to grid correction value for a 'record' feature would be awesome.  Maybe when you switch to the active record this ground to grid value could also be applied.
AmirBar-Maor
