Field calculator enabled in Parcel Details window
2235
09-04-2013 07:53 AM
Status: Implemented
CourtneyGordon1
In Parcel Editor, it would be very helpful to be able to use field cacualtor in the Parcel Details window in order to change multiple line types and categories at once.
4 Comments
TiffanyPuett1
You can shift-select multiple rows and choose "set template" form the context menu. However, you are limited to only that value. I would like to see it work with all of the attributes in your lines as you mention.
KoryKramer
This can be done using the Editing Attributes window
AmirBar-Maor
In ArcGIS Pro you can calculate fields on any parcel features.
Parcel features in Pro are simple feature classes and layers.
You  can use the Calculate Field as well as the Calculate Geometry.
KoryKramer
Implemented in ArcGIS Pro 2.7.
See Ideas in ArcGIS Pro 2.7: Something to Celebrate
And check out what's new in ArcGIS Pro 2.7!
