Divide Tool Feature Template or Inherit Original Parcel Attributes
4549
12
05-17-2024 01:55 PM
Status: Open
LucasBeauchamp
It would be really convenient if the divide tool had options to use feature templates or inherit the original features attributes (like the merge tool). Our fabric has parcel type subtypes and each time I divide a polygon it resets the attributes and therefore doesn't show up in any of layers due to the subtype definition queries. I then have to go turn on a no def query layer (which takes forever to draw) then I can assign it the correct subtype and then it will show up again. But then I also have to attribute it from scratch. If the tool were able to use feature templates or inherit the original parcel's attributes this would save me so much time.
12 Comments
-_Ashley-B-Potter_-
@JasonCamerano
I am still encountering the same issue despite confirming that the split policy was updated. Is there a possibility that the functionality to utilize a template, like the merge feature, is being considered? This enhancement would be particularly advantageous for the Mappers in my department, as they do not currently utilize this tool due to the additional step required to repopulate information.
JasonCamerano
Hey@-_Ashley-B-Potter_-
Would you be able to share more info on what is happening with your data?  You could also private message me with the data and workflow and I can take a look.  It could also be used to consider enhancing the tool to support a template feature.
