When copying a parcel fabric dataset using the Copy Tool, and using the associated data parameter to rename the parcel fabric dataset and parcel type feature classes, the Properties still reflect the original Parcel Type names.
Background:
Our entire process is scripted using arcpy. We go through creating the base file geodatabase with the parcel fabric schema, additional business/related tables, spatial reference, etc and then we make copies of it for processing each region’s data to break it up, then ultimately append them back together again into a single CONUS fabric. The Alaska region has a different spatial reference and has to be renamed because the datasets will reside in the same enterprise geodatabase. We use the arcpy.management.Copy gp tool to copy the Feature Dataset and rename everything using associated data input. This includes the parcel type feature classes but does not include the Parcel Type names found in the Properties/arcpy.Describe.
I would like for the Parcel Type names to be updated through exposing this property in the associated data mapping of the arcpy.management.Copy tool, or else have the controller automatically update them, or else have a tool in the Parcel Tools administrative toolbox that we can run to update the Parcel Type names (via arcpy) after the copy.
