Zoning and Parcel Areas missing
1168
05-16-2013 06:35 AM
KevinEarl1
I have zoning and parcel features on my map and they only show about half way thru my map. Anybody know why this is happening?
http://cop.maps.arcgis.com/apps/OnePane/basicviewer/index.html?appid=53a330d1b2594672b579901af101c64...
If you zoom in to the south side of the city, click on layers for zoning, you will notice that only some of them show but anything below Dicker Rd will not. Its pretty weird. I cannot figure it out.
On my desktop it shows. I bring in the public map to my desktop overlaying it and it shows them missing. Can someone help me with this?
MikeMinami
Esri Notable Contributor
Unfortunately, the services your layers are based on are not shared publicly. However, I can see the web map. The visible scale range of the layers is set such that they are not visible until you pass a certain scale. If you don't recall setting the scale visibility in the web map, then it's probably defined on the service itself.
You should have access to this URL
http://services.arcgis.com/Uj8MycSVzMEzm7ey/arcgis/rest/services/Current_Pharr_Parcels/FeatureServer...
If you look at the page, you may see min. scale value set. This will mean it's set on the service.
In the web map, I'm seeing these scales set
DrainDitches: 18,056
Parcel ETJ: 18,056
Pharr Parcels: 9,028
So these layers won't be visible until you pass a scale of 18,056 or 9,028 for the Pharr Parcels.
THanks,
Mike
KevinEarl1
Well I just replaced them with individual feature services and that took care of the problem.
The problem was that they were missing. The features on the sound end of the map were not showing up no matter what scale.
Thx anyway.
