X/Y coordinates do not display on MAP
1123
02-20-2012 04:08 AM
PatHayes
Hi All,
I've recently tried uploading a CSV file populated in Excel which contains a large list (720) of X/Y coordinates of motorway locations in Kent/Sussex UK.
The file seems to import successfully, yet the coordiantes do not display on the map.
If I zoom out to the full extent of the basemap, I can see the coordinates are North of the map, Yet the X/Y coordinates in the list appear to be correct.
I've attached an xls version of my coordinates, Can anyone tell me if there is a problem with the coordinates themselves?
Example:
y                    x
490933.26 107001.26
Many Thanks.
MikeMinami
Esri Notable Contributor
I see you figured out the answer yourself...
http://forums.arcgis.com/threads/50865-Problem-adding-layers
Mike
