Writing Custom Label Expressions using Arcade for ArcGIS Online?
7230
12
04-24-2019 01:26 PM
NevinValles
I'm not familiar with Arcade, but I'm trying to do a simple expression. I need to write an if-else label expression that will label addresses by their address number, unless there is a address unit number; then I would want the label to show the unit number. I've researched this documentation https://developers.arcgis.com/arcade/function-reference/logical_functions/ . I need a statement something like: If address is not Null than populate, or else populate unit number. I'm just not familiar with the Arcade structure.
DianaLavery1
Labels are a dynamic thing in ArcGIS Online.  The features that actually get labels to show up will probably change as you zoom in & out, and pan around.  At least that's been my experience.
KellyGerrow
Esri Alum
Can you share your map?
NevinValles
Xander was correct because there were records in the field that had spaces, once I reclaculated the expression worked perfectly! Thank you for the expression Diana and thank you for the correction Xander!
