Why is the 'OK' button to save changes to html in pop-up configuration greyed out?
1654
05-03-2023 07:40 AM
SimonCrutchley
I'm trying to edit the html for a pop-up in Map (new viewer), but the save button is greyed out. It was great to be able to make changes in Map Classic, but the option seems to have gone. Why have a link to open the html, if you can't save it?
RussRoberts
Esri Notable Contributor
Once you are done with the HTML snippet you click on the button again and the Save button will be active. This gives you the preview of the HTML text block.
RussRoberts
SimonCrutchley
Thanks, but I must say that is totally counter intuitive; I expect to save in html, not have to go out of it 🤔.
Still, I now know the answer, so thanks. 🙂
