Why do AGO search results differ?
922
05-17-2011 02:04 PM
DonBarker
I get different search results from different AGO search entry points.
I was browsing Javascript map templates and used the search function in the "Compare ArcGIS.com Web Maps" template.  Search term "fire" produced a map called "Fire and USGS Protected Areas".
I wanted to see this in the ArcGIS.com map viewer.  I searched different combinations of
fire usgs protected.
The map came up when searching with the AGO "Search for Map" function.
But when I did the same searches with "Find" + "in ArcGIS Online" in the map viewer, I got no returns.
Anyone from Esri know why?
Thanks.
MikeMinami
Esri Notable Contributor
The Find option in the map viewer filters its results to only show you items that can be added as a layer to the map (services). The general search of ArcGIS.com shows you all items.
Hope this helps,
Mike
