Layer in ArcGIS's Webmap
1242
05-23-2011 02:53 AM
malinfink
I want to use the servie webmap but can't find out how I have to save my point-shapefile-layer to be able to show it there. What do I have to do?
MikeMinami
Esri Notable Contributor
Currently, you can't upload data and add it to the web map. The only layers that can be added are services running on ArcGIS Server.
If you have a limited set of points that you could enter manually over the map, you can do so. From the map:
1. Click Add
2. Click Create Editable layer.
3. You can now add points.
We are working on allowing you to display different data types, such as shapefiles and CSV files over the map.  Pricing has yet to be determined.
Mike
malinfink
Too bad... 😞
but thanks for your instructions, Mike!
Where do I find out when it's possible to use shapefiles?
