When I add WMS layers to a web map, the Group Filter widget in my Web App no longer works. Is this expected?
1608
03-11-2019 04:19 PM
DrewSmith3
I've built a web map that has three layers (featured layers (hosted on AGOL).  I then used the WebApp builder to create a Web App from the foldable theme.  To this I have added the Group Filter widget and I've added three filter groups.  When I launch the App, the filter groups work fine with only these three layers.  I also need to add some other WMS layers from a Canadian Provincial website ( BC Data Catalogue).  I add these to the map and then launch the web App again and the Group Filter groups are no longer available and I can no longer apply the filters.  Is this expected behaviour?  I can't find anything about this in the descriptions of the widgets.
JasonRogers1
Thank you!!! I had the same issue happen to me (using Portal 10.5.1), and after removing the WMS layers the Group FIlter now works!
Obviously this is a bug, but at least now my Group Filter works again.
