When attempting to Create a New Web App, configurable apps will not load.
5206
02-04-2016 09:33 AM
AbbyBuchhop
When I attempt to Create a New Web App, the Configurable Apps tab "gets stuck" loading and will do so forever- never loading any of the configurable templates. To get around this, if I know the app template I am looking for I typically just search it and configure from there. But I would like to see the catalog of configurable app templates without the unnecessary go-around. Does so in Mozilla and Chrome and have just updated those, in case old versions were the cause.
DerekLaw
Esri Esteemed Contributor
Hi Abby,
Are you using ArcGIS Online or Portal for ArcGIS? If the latter, which release?
Have you tried to troubleshoot by clearing your web browser cache?
Hope this helps,
AbbyBuchhop
I am using ArcGIS Online. I did not have any success with loading the configurable app menu, even after clearing my web browser cache. I tried to do so in both Chrome and Firefox.
>>> Derek Law <[email protected]> 2/5/2016 12:04 PM >>>
GeoNet ( https://community.esri.com/?et=watches.email.thread )
reply from Derek Law ( https://community.esri.com/people/dlaw-esristaff?et=watches.email.thread ) in Web GIS - View the full discussion ( https://community.esri.com/message/585807?et=watches.email.thread#585807 )
Hi Abby,
Hope this helps,
Reply to this message by replying to this email, or go to the message on GeoNet ( https://community.esri.com/message/585807?et=watches.email.thread#585807 )
Start a new discussion in Web GIS by email ( mailto:[email protected] ) or at GeoNet ( https://community.esri.com/choose-container.jspa?contentType=1&containerType=14&container=2055&et=watches.email.thread )
Following When attempting to Create a New Web App, configurable apps will not load. ( https://community.esri.com/message/585807?et=watches.email.thread#585807 ) in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe ( https://community.esri.com/unsubscribe.jspa?email=acurtis%40co.lucas.oh.us&token=1c234f6f2a441391aba38995c85db44694c2a1260999f4a2ae342bc9e2e5d115 ) instantly from GeoNet, or adjust email frequency in your email preferences ( https://community.esri.com/user-preferences!input.jspa )
DerekLaw
Hi Abby,
Are you an administrator in your ArcGIS Online organization? If so, can you please check if the configurable application templates have been enabled for your organization?
  • Please go to 'My Organization' > 'Edit settings' > 'Map'
  • Under the 'Configurable Apps', is there a group assigned to this parameter?
If this parameter is not set, can you please select 'Esri Default'? Then click Save. This should enable the configurable application templates for the ArcGIS Online map viewer.
Hope this helps,
