What is the difference between views and requests?
4275
06-15-2016 11:48 AM
DavidForbuss1
What's the difference between "views" and "requests"?  On my usage stats page for a feature service, the number is displayed as "requests", and it is substantially higher than the view count on the app in which the feature service is being used.
KellyGerrow
Esri Alum
Views show the number of times the item has been viewed or opened. The view count will increase when you open the item details page or open the item in the map viewer. Requests show how often a request is made to your hosted service. The count will increase by one, each time the service receives a request. This includes actions such as panning and zooming in the web map or when the service is queried via a web map or application. The requests number should be higher than the views of the item if the service is used in applications.  Read the following documentation for more details:
Item details—ArcGIS Online Help | ArcGIS
-Kelly
DanPatterson_Retired
useage, views and downloads section of this may be what you are referring to
Edit
too slow on the draw
DavidForbuss1
Ok thanks for the replies : )
