What is the correct CSV format to map exact locations with values?
1022
03-08-2024 10:36 AM
jochoa6
I'm having trouble finding the correct resource I need.
I have a CSV file with addresses, lat and long, and values. I don't know how to format the CSV correctly to map the exact points and capture the values. Or maybe I have to do that separately? I don't know. Please help.
JakeSkinner
Esri Esteemed Contributor
Hi @jochoa6,
Can you upload a sample of your CSV file?
ChristopherCounsell
MVP Frequent Contributor
https://doc.arcgis.com/en/arcgis-online/reference/csv-gpx.htm
You need to have a clean table with column headings. ArcGIS Online will try to guess the fields and type, but you can correct it when you upload it.
If you think your table is not clean or is not working, see this article for generic issues that may be occurring:
https://support.esri.com/en-us/knowledge-base/problem-generic-errors-from-uploading-and-published-cs...
