Weighting Features Based on a Field Attribute Within the Same Layer in AGO
1705
09-03-2020 07:31 AM
CourtneyDunn
Is it possible in arcgis online to weight certain features to ensure they display over other features within the same feature layer?  I have bridges and roads within the same linework and am looking to display the bridges over top of the roads but in some cases they are hidden underneath. See photo below, the purple arrows under the red line indicate the bridge.
AmandaPutri
Update, I just looked around in AGOL and found that you can turn on the 'Display features by value order' to achieve this.
Drag the symbol to the desired order and when you turn the option on, the symbols should display accordingly in the webmap.
AmandaPutri
Hi @CourtneyDunn, did it work for you at the end?
I am looking into achieving similar thing where I have a feature layer symbolised by attribute. I need for some of the symbols prioritised over the other symbols. I tried setting up the feature weight in ArcPro but it does not seem to carry through to ArcGIS Online. Or maybe I missed a step along the way?
Thank you.
AmandaPutri
CourtneyDunn
That's great - this is a new feature since 2020.
