Web Map Overview in Update?
1290
06-26-2025 05:19 AM
laurentideicesheet
In the June 2025 arcgis online update, the overview page of maps changed. Now, they no longer show the layers used in the map. This was a convenient way to access the specific layers in a map quickly (accessing them inside the map takes longer). Is this functionality gone or am I just missing where it went?
TrafficOpsGIS
They are still there under the "Layers" section, it is probably just not showing up for you due to how slow everything is in AGOL after the update.
MichaelVolz
Esteemed Contributor
Just going to the Home page of AGOL is taking a very long time right now, even after clearing Chrome browser cache twice.
laurentideicesheet
This was exactly the issue. Thank you so much!
DanielFox1
Hi @MichaelVolz
We are aware of an issue with ArcGIS Online performance at the moment. Esri is working towards a resolution as quickly as possible. If you are able to create a Tech Support case, your account will be able to be attached so you are notified about updates
https://status.arcgis.com/
DanielFox1
This issue should now be resolved, please clear your browser cache if needed, if you are still experiencing an issue please log a support ticket with your distributor to investigate further.
