Web Map how to show lines and points inside a polygon (municipality boundary)
757
03-04-2025 12:02 PM
SanchezNuñez
Good afternoon,
When zooming into a municipality polygon, is there a way to display only the portions of the line and point layers that are located within the municipality?
Do we need to clip these layers to show only what is inside?
Also, is there a way to display the label of these points and lines, like specifying a distance?
DanielFox1
Hi @SanchezNuñez
Unless you have a filter perhaps that uses a rule to intersect or contains I think the idea of clipping is the best option. I may be wrong and welcome other ideas. But this might be something to stick into the Ideas page.
Ensure also your layers have the correct visibility setting and ordered correctly so they can be seen on top of non-transparent layers
